Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Dishwasher beeping The dishwasher has stopped into the cycle with all 4 lights on the right hands side flashing and continously beeps. All filters etc checked and cleaned. Can't get away from this stage now after turning on and off and disconnecting from wall. Also rinse aid low warning light still on after ample rinse aid added time and time again. Please help!! Same and another problem already reported!
  • Anonymous Mar 27, 2014
    just added rinse aid
  • 944 Answers
Here is the link to the manual if you need it; http://www.baumatic.co.uk/products/discontinued-models/dishwashers/freestandingdishwashers/BFD60SS I couldn't find anything that suggests a solution in the book. check this thread below for the reset procedure for another model - it may be worth trying; http://www.fixya.com/support/t137657-need_reset_dishwasher_but_dont_know other than that it sounds like the control circuit board has problems. unplug your machine and wait half an hour. undo the control housing by a few screws on the top inside of the door and maybe plastic clips moulded in the edge of the housing. look if any components on the board are obviously burnt or water damaged - sometimes they fail without visual signs but you might spot something. If you fancy replacing the board yourself, just make sure you take a picture of how it was wired up, and post me back the serial number and manufacturer on the board and i will try and source one for you - these boards on their own are rarely that expensive and are often in a lot of other manufacturers models so are usually easy to find. Hope this helps :)
Posted on Mar 14, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 14, 2007
    your local electronic hobby shop or similar should be able to test most of the components on this type of board, and possibly fix them - for sure they would be able to order a replacement, avoiding the premium put on by so many manufacturers.
SOURCE:
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
All the lights are flashing
check on the other post http://www.fixya.com/support/t135923-dishwasher_beeping Hope it helps:)
Dec 11, 2006 | Baumatic 24 in. BFD60SS Free-standing...
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
672 people viewed this question
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
