Question about Refrigerators
Fridge runs 24/7. Tried to adjust thermostat. It goes off, but comes right back on after a minute or two, then stays on. It's a side by side GE. Freezer ok, Just runs all the time. Why?
  • 36 Answers
Is it freezing things? if not then your compressor is probably getting weak. check the back of the freezer on the back panel and be sure there is no frost. frost means defrost problem. also make sure the fan is running. check the condenser coils and clean them. good luck
Posted on Dec 10, 2008
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Why isn't our refrigerator staying cold? It is staying around 50 degrees and no lower.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Fridge not staying cold
did you let the fridge stay in it's new place for 24 hours up right before turning it on?
Try turning it off for at least 24 hours and start it back up again.
If you moved it on its side the compressor oil flows into the lines and must beable to drain back down before using it.
If not you'll seeze the compressor.
not good.
Jun 25, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
