Question about Brother MFC 8440 All-In-One Laser Printer
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
    Sniper:
  • 56 Answers
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Posted on Jan 15, 2009
    President:
  • Brother Master
  • 990 Answers
Open the document feeding cover you will see many rollers ,use alcohol to clean it ,should take care your problem
Posted on Dec 10, 2008
MFC-8710DW
I am going to assume you are using the Auto Document Feeder for when you are copying and faxing.
When you lift the scanner top (As if you are placing a single document on the scanner glass) there is a small strip of glass to the left (normally) of the main scanner glass. This is the ADF scanner location. You will find that there will be two marks on this glass at the points you get lines on copied and faxed documents. Normally this is ballpoint ink that was not completely dried when fed through the ADF or Twink (Whiteout) that was not completely dry when fed through the ADF. Using rubbing alcohol or other cleaning products of similar gender clean this mess off the glass. If it does not come off it could be actual scratches on the glass which can only be fixed by replacing the glass.
Sep 02, 2014 | Brother FAX Office Equipment & Supplies
Faxes sent are being received with lines on the pages
You need to clean the glass real well, the narrow one if you fax from feeder and the big glass if you fax from flatbed. After cleaning you power off and on so it will calibrate to clean glass. Test by making a copy, the copy will look just like a sent fax will look. If you still have streaks you may need a new CIS scanner, around $60.00
Jan 08, 2010 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
Brother mfc-8440 printer/fax
you need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Nov 13, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Brother 8440
ONLY FROM A AUTHORIZED BROTHER SERVICE CENTER. ABOUT 59.00 - BROTHER TECH
May 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Can't make a copy
1: power off and power back on. 2: see the original manual for resetting to factory defaults.
May 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Adf hinge for mfc 8440 where to buy
Very common fault most Brother dealers carry this item, any service agent should stock, ring brother and ask details of your nearest printer agent.
Oct 20, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 All-In-One Laser Printer Logo
140 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
