Question about Dishwashers
WATER DOES NOT ENTER.
HAVE A KENMORE MODEL 16849 AND THE TIMER STARTS, BUT THEN NOTHING HAPPENS AFTER THAT. NO WATER ENTERS OR NO SOUND OF ANYTHING. THANKS JIM
  • 41 Answers
Your fill valve may of failed
Posted on Dec 11, 2008
What is wrong and how do I fix my kenmore 600 series washer?
If this is a top load washer; then the "LID Switch" is broken. Go to www.sears.com/parts, enter your model number and you'll see the switch listed.
Aug 26, 2014 | Kenmore Washing Machines
Cycle won't start allowing water to enter
This might be the timer that has a bad contact or it could be the water valves are bad or the power to the switched parts is bad.
Dec 02, 2013 | Kenmore Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Machine fills with water , then enters wash cycle without the agitator doing anything
on the top of washing machine there is a slot where the rinse relay is located,this inexpensive part is usually the problem.turn washer off and remove the two screws inside your washer,take a good look at the part yo u can usually repair with tape.
Mar 10, 2013 | Kenmore Washing Machines
I have a 10 year old Kenmore washer that has suddenly stopped working. It is full of water ( and clothes) and will not go into any cycle.Nothing happens but a ticking sound for a few seconds, then it...
The timer is what appears to be failed in this problem.
Typically - units are only supported for 10 years - but head over to RepairClinic.com and enter your full model number. If the part is available - it is very easy to change.
I can look for a replacement timer for you if you want - simply reply with your exact model number and I will respond with a direct link... as well as replacement instructions.
Thanks!
Nov 10, 2010 | Kenmore Washing Machines
My wahing machine (Kenmore 90 series, toploading) won't go past the agitate cycle.
After agitate - the next cycle is drain.
Nothing would prevent this from happening in the logic sequence except a faulty timer.
Sears website or repairclinic.com will have the timer when you enter the full model number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 16, 2010 | Kenmore Washing Machines
Washing machine is Kenmore mod. 110 22422100. After setting load size and time setting I pull the dial and sometimes(most of the time) water won't fill and the agitator will agitate. What is the problem...
You have a broken point inside the timer. I hate to say that there is no cheap solution. You will have to replace the timer. There is no rebuild kit or anything like that to repair the timer. I know of two suppliers where you can buy a replacement. I use these sometimes when I regular supplier hasn't got a part in stock. I checked the price at both for you and found the best price at www.appliancepartspro.com . their cost if $123.08 plus shipping. They ship same day if before 4:ooPM. Their Part Number: AP3020181 . When you go to their site enter either your model number or this part number. If you enter you model #, scroll down until you find the timer, Th part # will take you straight to it. I sure hope this helps.
Please rate solution
Sep 07, 2009 | Kenmore Washing Machines
Will not drain
If the drain lines are clear, test the drain pump, and see that drain pump is not clogged by removing it and cleaning.
If the drain pump is fine, then it is probably a defective control timer.
You can find machine diagrams and replacement parts by entering model number here.
Dec 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
