Question about IBM ThinkPad T41 Notebook
Overclocking IBM T41
Hi, Can you suggest what is the right way to do overclocking for my laptop? What software to use, how far should I take it. What are the risks and how can I avoid them. Thanks.
  • Dinoza
    Dinoza Mar 01, 2007
    Thank you Sandrew.
    I think there are a few softwares that can do the job. Aren't they supposed to take care of everything and ensure the clocking is not harmful?
    Do you know anything about these applications? If so can you suggest one?
    Thanks!
    President:
  • 2,961 Answers
I doubt very much that your laptop can be clocked as you need to change the speed, timing or multiplyer in the bios, which can do more harm than good as the memory timings can be wrong and the system unstable. You will also find you are unable to find any changeable menus in the bios refering to the processor speed as they are normally locked out by factory. The only menu you may find is lined similair to 'Optimal settings'.
Posted on Mar 01, 2007
  • andrew pester
    andrew pester Mar 01, 2007
    I have used overclocking graphics card programmes but not processor.
Is there any way to overclock the cpu on an HM55 based Laptop?
No. Overclocking a laptop is out of the question and it will make the chip run crazy hot. It could be done if you cut away some of the case. But overclocking makes only a tiny difference in performance you will see way bigger gains from switching to and SSD drive.
May 05, 2015 | Intel Computers & Internet
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    Overclocking lifebook T730
    Unfortunately the hardware in the lifebook does not allow overclocking. it can be done but requires both hardware and software hacking to do so.
    Mar 09, 2012 | Fujitsu LifeBook T730 Tablet PC Intel Core...
    Overclocking
    There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
    http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
    Nov 27, 2011 | ASUS A7V880 Motherboard
    Plz help
    Try Systool for Intel overclocking. You use this software at your own risk !!!!! Get Systool by clicking on the link below >>>>>>>
    http://www.techpowerup.com/systool/
    Regards.
    Feb 19, 2010 | Acer 4220-2346 Notebook
    HOW TO OVERCLOCK LAPTOP TO BOOST SPEED?
    Overclocking on computers is done via the BIOS, if the BIOS on the computer supports it. The T23 hasn't got this ability.
    Late model desktop computers have this capability with Gigabyte motherboards as well as other makes, overclocking will generate greater heat problems and additional CPU cooling may be requires.
    Jun 29, 2009 | IBM ThinkPad T23 2647 Notebook
    Overclocking locked on 945gct-m2 mobo
    There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
    May 30, 2009 | Intel Computers & Internet
    Overclocking
    are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
    CHARCOIS
    Aug 24, 2008 | Intel (P42000400256SK478) Pentium 4, 2 GHz...
    Gaming processor.
    No lie, the best and cheapest you will find for gaming, and for overclocking is the AMD Athlon 64 X2 2.6Ghz "Black Edition" It is a dual core, AM2 socket, and has unlocked multipliers you can access through your bios, which is perfect for a newbie to mess around with overclocking. Go to www.tomshardware.com and search for it, they did a big article all about overclocking it which will explain why its so great. Best thing is its 90 bucks on www.newegg.com , just plan to buy a fan and some thermal grease, wont run you much more. Good luck and happy overclocking.
    Jan 26, 2008 | Computers & Internet
    Overclocking failed
    Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
    Sep 01, 2007 | ASUS P5RD1-VM Motherboard
    IBM ThinkPad T41 Notebook Logo
    890 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
