Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Hey i want to know whether fridge requires DC power supply or AC power supply
  • Whirlpool Master
  • 5,568 Answers
DC applied to any standard refrigerator would quickly damage the compressor motor and any fans present since these are all AC only motors.
Some (probably no longer produced) units used DC in their operation; - Peltier Efffect units that used a semiconductor device that acts as a 'heat pump,' removing heat from inside the cabinet and dissipating it outside. - A new type of compressor that hummed like a low frequency speaker and surely used DC in the generation of the driving signal.
The first proved to be less efficient than our near century old compressor system and the odd low frequency noise produced by the second could not be contained adequately for home use.
Posted on Dec 11, 2008
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Prolink h5201
No. You must use a 5V ac adapter/power supply.
But are you certain that you need 5V ac to power your modem ? Where are you located Jane ?
22.April.2014
Feb 16, 2014 | Computers & Internet
No power to refrigerator unless it is hooked up direct. Think it is 12 volt dc supply connection. Could this be the problem only able to get partial # on part c1c 5122 is all we can read.
there is an inverter built in to the power supply that converts dc to ac to run the compressor if the fuse is ok. you will have to replace the supply . or for traveling you could hook up a small inverter to opperate the fridge while traveling this could be connected to the 12 vlt line for fridge power as it will not take much more power than the the fridge needs.
Feb 21, 2011 | Thetford Norcold® Model DE0061
TC Electronic D-Two Power unit locked up display
I don't know if this will help. Have you looked for a battery on the circuit board that backs up the memory? A lot of synths use them and when they go the unit quits functioning. Some will start right up again once the battery is replaced others require a system update through a download. Anyways I always recommend contacting the company in question. They should be able to tell you simply whether it needs servicing or not:http://tcsupport.custhelp.com/cgi-bin/tcsupport.cfg/php/enduser/ask.php
Jul 14, 2010 | TC Electronic Finalizer EXpress...
I have a rhodes 660, and it doesnt trun on. all u hear is a buzzing sound. does anyone know whats wrong.
This is LIKELY a power supply problem. The unit should have a label telling the power requirements. Match the polarity on DC units as well as the type AC od DC and voltage and current.
I suspect the input voltage from the supply is way lower than the required.
Apr 22, 2010 | Music
Needs a power supply
Before you can set about obtaining a power supply for your unit, you need to know...
1. Voltage Output
2. Current requirements of your theatre system
3. Plug type and size
4. Type of power ( whether AC or DC)
Apr 16, 2010 | Audio Players & Recorders
I have a thermoelectric wine cooler (heintzman DC2-40C) that no longer cools as it should....help....
Thermoelectric devices (or modules) require direct current (DC) for operation. Alternating current (AC), the form of electricity found in wall outlets, causes a thermoelectric device to alternate between heating and cooling, rendering it effectively useless. "Ripple" is the AC component of DC current and occurs when a power supply does not completely convert AC current to DC current.
You just might want to find out why the AC is not turning to the DC required, This could be a matter of chaning outlet plug or maybe the Ower pack that coverts the AC to DC.
Jan 01, 2010 | Refrigerators
I lost the power supply and would like to know what voltage and amps in need in a power supply to operate the maxtor
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
Oct 30, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
