Question about Thomson 14MG135 14" TV
Help me !
I have one tv thomson 14" model : 14MG130g please help me with diagram for this type tv. thanks geni
  • 17129 Answers
SOURCE: thomson tv model 25DK91XD power supplay smps
SMPS circuit consist of the same block diagram and all what is need for you is to trace from the main AC to DC conversion- the rectification , then the DC power applied to the switching/chopper device through the SM transformer.
Now check the pulse generation, if the IC is producing to start off the switching pulse. If not the IC can be defective. If there was a burn out the corresponding circuits must be changed totally as damage could have occurred. Also the SM transformer is a suspect., the current detector opto -coupler is also a common failure.
Please find some tips from the following link: SMPS
Posted on Nov 25, 2010
0 characters
1 Points
JVC 29 inch Color tv Model no 29ss16 flyback no JFO 501-21168 is not available in Pakistan Please tell me Flyback Replacemint No?
Just try this link. It has circuit diagrams to some popular brand CRT TVs. Hopes that it might help you find out the exact number of the flyback transformer. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 16, 2014 | Thomson 14MG135 14" TV
Problem coler tv
What is the problem with your TV. Provide more details please.
Mar 22, 2013 | Thomson 14MG135 14" TV
The line output transformer to your TV should be checked and replaced.
Aug 27, 2012 | Thomson 14MG135 14" TV
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.
If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.
Direct hookup with cable or what?
May 02, 2012 | Thomson 14MG135 14" TV
I need the schematic diagram for 14mg135 thomson tv
May I know if the chassis number of your TV is ITC008? If not, please let me know what its chassis number.
Jan 10, 2012 | Thomson 14MG135 14" TV
14MG135 4:3 14" Television 14 in. Is this a
No this is not a digital tv. You will need a converter box/set top box. I am posting the specifications. Where it says tuner it would have to say atsc and/or qam for it to be a digital television
Product description Product Identifiers Brand Thomson Model 14MG135 MPN 14MG135
Key Features Screen Size 14"
Technical Features Screen Type Non-Flat Screen Aspect Ratio 4:3 Built-in Tuner NTSC, PAL, SECAM Adjustable Color Temperature Without Adjustable Color Temperature
Connectivity Front Input Connectors Audio (RCA) x 1, Composite x 1 Rear Input Connectors RF x 1
Audio Features Number Of Speakers 1 Speaker Power 1 x 3.5 Watt Audio Type Mono Subwoofer Without Subwoofer Audio Leveler Without Audio Leveler
Miscellaneous OSD Languages Danish, Dutch, English, Finnish, French, German, Greek, Italian, Portuguese, Russian, Slovakian, Spanish, Swedish, Turkish Parental Control Proprietary Sleep Timer With Sleep Timer Remote Control Standard Additional Features Headphone Jack
Jul 19, 2011 | Thomson 14MG135 14" TV
How to unluck my 14" 10 years old television
Sorry,u can't unlock secret codes.Tries unplug,replug tv an hour later.Tv is reseting back to factory default,might erase the codes too?
Sep 09, 2010 | Thomson 14MG135 14" TV
were you able to get the problem solved Even I have the same problem
Sep 08, 2008 | Thomson 21DC320 21" TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Thomson 14MG135 14" TV Logo
56 people viewed this question
Top Thomson Standard (CRT) Televisions Experts
Are you a Thomson Standard (CRT) Television Expert? Answer questions, earn points and help others
