Question about IBM 6400 Model 010 Matrix Printer
Power issue - will not turn off
Unit will not turn off
    President:
  • IBM Master
  • 990 Answers
Replace the power switch
Posted on Dec 10, 2008
I have a Intertherm heating and airconditioner unit and the ac works but when I go to turn on heat I get a humming noise only 2009 or 2010 Mobile home unit
turn power off and put red wire in with white wire at tstat and turn power on. if heat works it's possibly a configuration issue or a tstat issue. keep us posted.
Nov 03, 2017 | Intertherm Heating & Cooling
Waring pro electric deep fryer won't turn on. No issues with the outlet, used twice before with no issues. What's wrong with it? No parts missing
Turn power off. take off bottom cover and check power is coming the the Heater coils. If no power check for blown fuse. If you have power at Heater Terminals then you need a new Coil
Mar 22, 2015 | Waring Kitchen Appliances - Others
Flashing reset power
The HP support site has the following solution for your problem. Appearantly, If turning the power off by pressing the power button and then turning the power back on, by pushing the power button does not solve the problem, the printer needs to be examined by a service technician. When this type of problem happens to me, I will always unplug and remove all power for the device, be it a printer or computer and let it sit for a few minutes before plugging it back in and turning it back on. This gives the unit time to cool down and reset itself. I pasted the solution page excerp from the HP support site below to show you exactly what HP suggests. I hope that you found this information helpful. If I can be of further service to you, please let me know. Brian All lights on the all-in-one are flashing and there is a Power Reset error message in the LCD. You may be experiencing all or one of the following symptoms:
  • All lights flash and the Power Reset message displays on the LCD when the unit is first turned on or during any normal operation of the product such as printing, changing cartridges, copying, faxing, or remaining idle, while the unit is turned on. Solution
  • Follow the steps below until the issue is resolved. All of the following steps might not be necessary to resolve the issue. Step one - Turn the unit off and on
    1. Press the Power button to turn the unit off.
    2. Press the Power button to turn the unit back on.
    3. Try to print a simple print job or copy.
    • If the issue is resolved, you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved, continue to the next step.
    Step two - Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Jan 04, 2011 | HP Officejet 6310 All-In-One InkJet...
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Jul 28, 2009 | Nintendo Wii Console
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset power message when I try to print on my HP6310 all in one
  • Step two - Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Jun 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset power
To do partial Reset.
1.Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit.
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Feb 24, 2008 | Panasonic SC-HT730 System
IBM 6400 Model 010 Matrix Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
