Question about Zenith TVBR1922 19 in. Combo
Can't get auxillary channel
I recently had to buy a new remote and reprogram my channels and I can get them all except auxillary so I can't watch dvds because I actually have a 20in Zenith Tv that is not a tv/vcr combo, There is no button on the remote or the tv that allows me to get that line. How do I do that?
    New Friend:
  • 50 Answers
Have you tried selecting it in the channel section of the menu? The main menu also might have an input option since there is no "input" or "source" button on your remote.
Posted on Feb 28, 2018
My dear friend your problem is the charge motor belt who is in bad conditions you got ta replace him.Good luck.
Posted on May 28, 2008
SOURCE: I cannot reset the channels
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Posted on Dec 25, 2008
  • 20 Answers
SOURCE: my tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Posted on Jan 02, 2009
  • 81 Answers
SOURCE: my tv is locked
They have an internal battery for transport between rooms so as not to lose any pre-programed channels or info while unplugged. So to beat this you will have to unplug it for a few days and let it clear its memory. Mine needed almost a week but when its turned on after the right amount of time it will ask to do a channel search. So make sure you have it hooked up to cable before running that search or you will have to repeat the previous steps. Hope this helps.
Posted on Jan 05, 2009
  • 19396 Answers
SOURCE: Remote stopped working!
To turn off the 100 button you need the original remote.
Order a replacement from one of the sellers below:
Used Original Zenith Z20LCD1 Remote Control
Zenith Z20LCD1 Replacement Remote
Posted on Mar 09, 2009
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
I lost my remote, how can I reprogram the channels?
2 ways you can buy a new remote from mr or use your buttons on the set by hitting menu and go to channels and scan channels
Jan 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
well, i got a one for all remote from a wal mart or some where else, and i have a sylvania tv. it works for my tv. might want to look into that.
May 27, 2009 | Sylvania Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Jan 08, 2008 | Televison & Video
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Zenith TVBR1922 19 in. Combo Logo
42 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
