Question about Olympia Supertype 330 Typewriter
Ribbon will not advance fully making letters overlap on the ribbon, so the next letter comes out light. Is there an adjustment for ribbon advance. We have looked all over on the boards and could not find on. This is a Olympia Supertype 330. Any help would be great. Scott
  • Olympia Master
  • 3,594 Answers
If I remember correctly Code + comma (,) It may be the period(.) or slash(/) one of these should change the ribbon advance.
DickyO
Posted on Dec 10, 2008
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
Ribbon doesn't raise up enough to let the letters strike it. Is there an adjustment somewhere?
If it dosen't lift at all wiggle the large black gear bakand forth a few times they do get tooth for tooth.
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
I have a Royal Signet 25 Typewriter that works fine, except that the type is uneven and some letters come out very light, others are fine. I think it may just need cleaned and adjusted, maybe? Any...
It might be a ribbon problem. take the ribbon cassette out and look at where it has been typed on. Do the characters overlap? If so, get a new one. Or the ribbon might be dried out. Is there an impression control? Set it on heavier print. If you have a different print wheel, try that too.
Feb 09, 2011 | Royal Office Equipment & Supplies
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
Nakajima typewriter model AE830. New ribbon installed. when typing printed letters appear only lightly printed on paper. Any way to adjust?
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
Jun 24, 2010 | Nakajima Office Equipment & Supplies
Only part of the character/letter is showing
make sure the ribbon is latched into place (should lock down) also check on the ribbon itself to make sure the print is in the middle of the ribbon and not on the very bottom, if the ribbon is locked down and types of the bottom of the ribbon, it is out of adjustment. if the ribbon looks ok, move the paper scale (the plastic piece on top of the platen) up out of the way, then push down sharply on the platen. if it moves down and clickes into place, it should work OK.
Jan 05, 2009 | Lexmark Wheelwriter 15 Series II...
Diagram to change ribbon cartridge
The cartridge just snaps on, printing half letters may be caused by the ribbon being folded over on itself or not moving look at the ribbon toward a light you should see each letter clearly thru the ribbon
Sep 20, 2008 | Swintec 7040 Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
Olympia Supertype 330 Typewriter Logo
179 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
