Question about Pool & Spa
Pilot light keeps going out. sometimes after three days or more.
I already replaced the RTD
Pilot light not coming on
Posted on Dec 27, 2008
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
If you have not already replaced the thermocouple then this may be the problem, If you
have already replaced the thermocouple with a "universal" this may also be the problem
as it may be a different length in relation to the flame of the pilot.
Feb 24, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a residential Lochinvar Solution Boiler (model RBN090). Around 7 years old. For past 2 weeks pilot light keeps going out. 2 repairmen have come out. We have replaced the Gas regulator, the roll...
Take notice of the wind conditions when it goes out. If there is a draft, the wind can come in the room with the water heat from the flue and blow it out. Or it can come in the room from another way and exit from the flue and blow it out.
May 12, 2017 | Heating & Cooling
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Sep 21, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot keeps going out
The pilot assembly, pilot oriface, and pilot burner should be cleaned and the thermocouple replaced.
May 01, 2009 | Heating & Cooling
Wolf oven won't light after only 3 years since last repair.
You could try a new thermocouple and/or cleaning the pilot assembly. The thermocouple is the tube that screws into the pilot safety valve and runs to the actual pilot and is heated by the pilot flame. If you change this part be sure not to over tighten the thermocouple into the safety valve as it can break. You should go finger tight plus a quarter turn. Also you should check to see if the pilot is solid, not weak. Thermocouples can be purchased from your local equipment service company, sometimes Home Depot has them for water heaters, be sure you get on with proper length. Hope this helps.
Apr 29, 2009 | Wolf Range Challenger CHR-6-1829-FT22...
Whirlpool water heater pilot light does not stay lite
I have a Lowe's Whirlpool water heater. I've experienced the same problems as I've seen described here. My pilot light started going out several times a day. It was not such a big deal, the tank is well insulated so the water would stay warm - I'd just re-light the pilot before going to bed and before going to work. That worked well for about three days, but the problem got progressively worse until it just would not light at all. I replaced the thermocouple with a Honeywell universal thermocouple that I got at Home Depot - that did not solve the problem. I'm very handy, so I decided instead of going through warranty service and having to wait three or four days for replacement parts, I'd buy a new gas valve at Lowes and try that. It cost $54.00 and it worked. By the way, I put the original thermocouple back in and the pilot light stays lit - it was definitely the gas valve and not the thermocouple in my case. It was a real pain to do since I had to drain the tank, but it only took about three hours total. From what I've read, these things last anywhere between six months and two years. That's ridiculous, but at least I have hot water now. If you are reading this because you are considering purchasing a Lowes hot water heater, DON'T!!! I started my search for a replacement gas valve at Home Depot, but they don't stock them. Lowes had 8 on the shelf. That tells you something right there - the water heaters Home Depot stocks don't need to have the gas valves replaced before the tank wears out - there's no demand for the valves so Home Depot doesn't stock them. Lowes probably sells 8 of them a week - all the boxes were shiny and new, not dirty and dusty like some items get when they sit around in home improvement stores.
Nov 11, 2008 | Water Heaters
Pilot light on heater
check the millivolt generator is working. this is the copper colored tube in the flame path. for spark perhaps the gap is too wide. the flame sensor electrically keeps the pilot valve open.
Dec 12, 2007 | Procom QL300TYLA Heater
Pool & Spa Logo
276 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
