Question about First Alert 24 Hour Timers - 2 For The Price Of 1
Directions on use for first alert daily timer tm220
Not sure how to set or use this timer....bought it last year and have since lost directions leaving me unable to figure it out
The instructions read
Begin with all of the segments pushed up
Push down the segments for the required "on"? time, each segment represents 1 hour
Rotate the dial clockwise until the "Time Now" is aligned with the pointer
Plug into outlet; plug appliance into timer
Posted on Jul 23, 2010
It looks similar to a timer i have for my fish tank. On the dial i have there are little black nodes and if you push them down for the time you want the timer to be on eg, a light to be on between say 8am and 5pm, then push down the dials from the 8 to the 17, using the twenty four hour clock. Once plugged in to a socket that is switched on all the time the dial will make sure that the plug put into the timer will only come on between the hours you stipulate. This is how my own plug works and so i hope this will help you. ElleLainey x
Posted on Dec 10, 2008
How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
Jun 05, 2013 | GARDENA Water Timer
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
Oct 24, 2012 | First Alert Hardware & Accessories
FIRST ALERT TIMER TYPE TM220
Timer is not identified. Web search does not show photo of timer.
Guessing you need help setting timer?
1) Open following link for 8 different photos of segments/pins that are located on dial of analog plug-in timers, and instructions how to set analog timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
2) If information above does not include your timer, then look down the full page on link above and find same-similar timer with instructions. Add a comment at any time.
3) Also add a comment with in-focus photo of your timer posted on Flickr so expert can identify timer for sure. Then include exactly what problem you are experiencing and what you have done so far to fix problem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 16, 2011 | First Alert 24 Hour Timers - 2 For The...
How do I set my TM220 First Alert plug in timer
Open following links to identify timer and read detailed instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Jan 04, 2011 | First Alert 24 Hour Timers - 2 For The...
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
How does this timer work? I lost pkg with info.
Rotate dial until current day and time line up with arrowhead located on inner dial.
The timer will turn on-off according to preset schedule
Dec 19, 2010 | First Alert Tm261 7Day Vacation Timer
Need instructions to set the First Alert TM220 Timer.
For the Model TM-220, 24 hour timer set as follows:
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1 hour.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Mar 19, 2010 | First Alert 24 Hour Timers - 2 For The...
First alert timer 220
First Alert 6262 Patterson Pass Road, Suite C Livermore, CA. 94550 1.800.458.1385 orders@vwimc.com
  1. Set current time with arrow at top of dial
  2. Time on, push and slide white pin
  3. Time off, push and slide grey pin
  4. Automatic override, use red switch on side
Comments on some sites that refer to this unit is dont waste your time .. heap of junk, wasted hours and it still didnt work.
So good luck
Please rate our help to keep the FREE service online
Aug 30, 2009 | First Alert 24 Hour Timers - 2 For The...
First Alert 24 Hour Timers - 2 For The Price Of 1 Logo
7,739 people viewed this question
Top First Alert Hardware & Accessories Experts
Gene Haynes
Tom Chichester
 Mikey
Mikey
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
