Question about GE Built-In 24" Double Electric Wall Oven
Older ge double wall oven mod.jk250 top section will not heat at
All bottom is fine
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
  • 112 Answers
SOURCE: GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
SOURCE: GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Posted on Nov 02, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Bottom oven of dacor double oven
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
GE Built-In 24" Double Electric Wall Oven Logo
275 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
