Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Pump Assembly Drive mechanism seperarted into two pieces
The rounded red plastic spindle is still in place on the pump assembly, but the metal extension that provides drive for the toothed belt that moves the brushes came out of the end.
Apparently hair and carpet fiber wedged itself between the two pieces and litterally pushed the two pieces apart. New pump assemblies in pictures appear to be one piece and all red plastic.
Is this a factory fix for a design problem, and how do I proceed? Is mine the newer style or the older style pump?
I can glue it back in with super glue I suppose, but it should be in warranty still. I would have to take it to another city for warranty repairs.
  • cm30rn Dec 11, 2008
    I think I have the same problem. I noticed my rollerbrush was not moving while cleaning the carpet, so I got out the manual and attempted to follow the directions, but they are not clear. I got better directions on the Bissell website but now I am stuck. When I took out the rollerbrush, I first noticed some chunks of plastic looking stuff. The belt was still on and the black plastic appears to have been the rubber coating of the belt. Well, I bought a new one, and following the online directions I cant seem to put it back on right. It looks like the top of thered pully broke. The black brush arm has the metal "toothed" peice stuck on it, but this part is shown inside the base unit in the directions. Does anyone know how to fix this???
I believe the pump assembly can be replaced it is a15 dollar part.that is what works the brushes. Ijust took mine apart and looked at it the end snapped off.
Posted on Dec 26, 2008
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Dyson canister won't fit snugly
I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
Best wishes,
Jun 22, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
Jun 06, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Belt on motor roller
no only take the bottom off ,there will be three screws,take the belt put in over the shaft of the motor , loop it ,run it over the silver spindle to the brush assembly ,replace the brush in the slot that it came from,the belt now is over the motor shaft running over the spindle ,and over the brush assembly,replace the three screws and you should be good to go.
Jan 31, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to change belt on bissell proheat powersteamer
There is a video on the Bissell website on how to do this, click here for the link:
Jun 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Proheat pump key
No; the new pump has a metal pulley which is more durable then red plastic pulley. be sure to place a 3/4 thick x 10 inch long (small shelf works) piece of wood under housing before removing top.
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Kirby vacuum
The Kirby air flow can be reversed to become a blower (not pump).
This is ideal for blowing up low pressure items such as air beds etc.
Take off the complete bag assembly by twisting at the bottom and unclip at the top.
Fit the flexible hose to where the bag attached, align the arrows and twist fully until located.
Remove the front brush assembly, lift the front head light flap, detach the belt by twisting the square knob to the red position (off). un-clip the front assembly.
Your kirby should be supplied with a box type attachment (air intake guard) that fits on the front covering the motor spindle and making the safety switch.
Once fitted your kirby should now blow.
Mar 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Floormate wheel assembly
You must remove the top gray piece it has six tabs 2 in front, two in back and 2 on sides where the foot pedals are. Be very careful not to break them. Then you cn remove screwsa nd install the piece.
Oct 22, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Oct 20, 2007 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
