Question about KitchenAid K45SS Classic Stand Mixer
Mixing bowl is jammed into the base and won't come out
I used a new mixing bowl on my 15 year-old mixer and the bowl jammed into the base so tightly, I can budge it! Tried everything and the handle solder even broke.
Any suggestions?
  • 1 more comment
  • cmartin808 Dec 11, 2008
    It's a Kitchen Aid Stand mixer model K45SS
  • forgetyou Mar 07, 2009
    My mixer is Artisian and the bowl is stuck.   It is only four years old
  • gary marzian May 11, 2010
    what type of mixer?
  • 41 Answers
You may have the old style frame which is why the bowl jammed old bowls are no longer avaible you may need to purchace a new mixer
Posted on Dec 12, 2008
KitchenAid KSM150 bowl won't stay put
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
Jul 08, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
We just purchased the custom kitchen aid stand mixer on a boxing day special. We used it tonight to make cookies and then could not remove the bowl from the base. We are going to try the icecubes. If this...
The bowl screws into the base and can get quite tight if the mixer has been turning thick dough or other mixes. We usually tap the handle on the bowl with the palm of our hand a few times and that generally frees it. The other posibility is that the bowl was put into the base slightly askew. This could be more of a problem as this can cause the base plate to get damaged. Usually though if this happens you would have noticed some bad noises almost instantly you turned the mixer on.
Dec 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Bistro Staned Mixer;Mixing bowl is stuck(?) to base
You have to twist the bowl anti-clockwise to release it from the base. Twist clockwise to lock it when using the beaters.
Nov 23, 2008 | Wolfgang Puck Stand Mixer
I just got a new Kitcheaid Artisan 5 qt stand mixer. i can't get the bowl off of the stand. seems like its too tight, and i can't budge it. is there something i can do?!?!?
These bowls can tighten during mixing. One solution is to fill it with ice while trying to unscrew it. Soaking the base with soap is another solution. In the worst case, the bowl and the cap it fits in are replaceable.
I have had to use a homemade strap wrench on others. Be careful not to warp the bowl out of round, or it will be un-usable.
Oct 22, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
253 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
