Question about Uniden 5.8GHz Cordless Phone
Uniden 5.8 ghz phone. Can you turn the ringers off and how ?
I have a 5.8 gh uniden phone with 3 handsets all together. There are just somedays I dont want to hear the phone ring at all ! My brother
gave me the phone set and he couldnt find the manual. If someone
can tell me how to turn off and on the ringer it would be so greatly
appreciated.
I know how to turn the ringer on low and high, I need to know if there
is a way to turn it off completely if possible?
thanks
johanna
  • Anonymous Mar 24, 2009
    how do i turn phone ringer back on
  • Anonymous Mar 21, 2014
    ringer on phone turned to silent. how do you start phone to ring again
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Posted on Mar 24, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Can't turn the ringer on to notify when a call is coming in.
Without the model, I can't be sure of the method you need to enable the ringer.
Some Uniden phones toggle on a Silent Mode if you press and hold the # key (below 9 on the keypad) for 3+ seconds on one handset. When turned on, the phone will ask how long (1-9 hours) you want the ringer to be disabled for the handset. If no key is pressed within 5 seconds, the handset will not ring until the # key is pressed and held again.
Other Uniden phones have a Do Not Disturb mode. This disables the ringer on all handsets.To disable this, press and hold the DND button on the base. The answering system will be turned on if it isn't already on when DND is in use.
The other options to mute the ringer include the volume down on the handset when the phone is in standby. Some phones will also adjust the ring tone volume in the menu.
I hope this helps. Please add a comment with the model of your phone for additional information.
Apr 29, 2016 | Uniden Cordless Phone
Handset does not ring but the answering machine unit does
Go into menu settings from head set and make sure ringer type is slected for a tone and then check and set volume at desired level
Apr 15, 2013 | Uniden 2.4 GHz Cordless Phone System
I have Uniden DCX700 phone- how do I turn the ringer on and off?
The DCX700 is an expansion handset for several different Uniden phones (DCT746, DCT748). To change the volume of the ringer, press the Vol + or Vol - button with the unit in Standby (not making calls). There are three ringer volumes: Off, Low and High. Pressing the Volume buttons will let you cycle through the list. The volume buttons are to the left of Talk below the LCD screen.
You can temporarily mute the ringer by pressing Mute while the phone is ringing.
The manual for the DCT746 is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT746Mom.pdf . All Uniden cordless phone manuals are available in numerical and alphabetical order here: http://www.uniden.com/scat/cordlessphones_mnl . The manual for the DCX700 handset (with registration information) is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCX700om.pdf .
I hope this helps.
Sep 21, 2011 | Uniden DCX700 2.4 GHz Cordless Phone
Have Uniden EX14560 and do not know how to turn ringer back on..can you help me?
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
Most Uniden manuals are available from Uniden on the product page or the support page. The product page is http://www.uniden.com/cordless-phones/24-ghz-extended-range-cordless-technology/invt/exi4560g/ . Then go to the Manuals tab. The direct link to the EXI4560 manual is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EXI4560om.pdf .
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
I hope this helps.
Aug 25, 2011 | Panasonic UnidenEXI3226 : Two-Line 2.4GHz...
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How to turn on/off ringer on DCX730
With the phone in standby mode, use up-arrow and down-arrow to change the ringer volume. The three settings are off, low, and high.
Full details are on page 10 of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCX730om.pdf
May 13, 2011 | Uniden DCX730 2.4 GHz Cordless Expansion...
I have an Uniden power max 5.8 GHz home phone but don't have the owners manual the handset won't ring and a icon of the bell on the screen is X ed out. i can't seem to figure out how to turn the ringer...
Sounds like the handset needs to be re-associated with the base unit.
If the manual for the Uniden PowerMax manual on the FixYa website for manuals is not the correct manual, go to the Uniden website and locate the manual there.
Dec 17, 2009 | Uniden Cordless Phone
I can not find my manuel. How do I turn on the
Adjusting the Ringer Volume
You can choose from four ringer volume settings on the handset (off, low, medium,
and high). With the phone in standby, use the up arrow or the down on the handset to adjust the
ringer volume.
You can find your manual online in PDF format here:
http://www.uniden.com/pdf/TRU9360om.pdf
Apr 20, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden 5.8GHz Cordless Phone Logo
4,486 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
