Question about Maxtor Hard Drive
Installation of one touch mini 4
I am reading the instructions and they tell me to connect in a certain order and it says that they are labeled. Nothing is labeled. I need help to connect this super simple hard drive. That I am probably making harder than I need to. Help!!
    Novelist:
  • 152 Answers
Hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Posted on Dec 10, 2008
Hw to get network key to unlock alcatel ot708
You can get the Network Unlock code for the ALCATEL OT-708 model Phone from here
Classicunlocking.com and Unlock it from Network lock using the instructions below.
Alcatel OT-708 One Touch MINI Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Alcatel OT-708 One Touch MINI mobile phones. If you enter over a certain amount of wrong unlock codes on your Alcatel OT-708 One Touch MINI mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Alcatel OT-708 One Touch MINI with a NOT ACCEPTED SIM Card,
2 - When the message "Enter Network Key" appears, enter the Unlock Code.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Alcatel OT-708 One Touch MINI is locked to.
OR
1 - Switch ON your Alcatel OT-708 One Touch MINI WITHOUT SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
CODE: The unique unlock code for your Alcatel OT-708 One Touch MINI.
Aug 06, 2011 | Cell Phones
MY MOUSE KEEPS LEAVING THE SCREEN, AND GONE FOR 10 SECS..ITS A DELL LATTITUDE 600 NOTEBOOK-FIREFOX, XP
Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5
Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Feb 08, 2011 | Dell Lattitude D600 Notebook
Hello, I have a Hitachi DZMV780A camcorder and I need a USB driver in order to transfer the footage from my camera to my computer. I have the apropriate cord but the camera doesn't show up on my...
I think, you have to install first the driver before connecting your device to your desktop. The driver gives the PC an instruction on how to read and detect the device when connected. try searching the internet for the driver, i guess your device's website has a support for it.
regarding the mini dvd. first make sure that your cd-drive is capable of reading dvd. otherwise, it can't be read. some dvd drives makes it hard to read mini dvd's due to the shape of it, and they are not designed for those. Try reading the mini dvd to other dvd-rom, and just copy the contents. either burn it to a normal sized dvd, or just make an image and copy it to your USB.
Jan 17, 2011 | Cameras
Replaced sparkplugs and sparkplug wires, now runs rough. I checked connections all tight. check firing orger, looks right. run good till I touched it. Help.
Check the firing order with the firing order diagram that I have uploaded, and if that does not solve the problem then remove the spark plugs and be certain that there is an even spark plug gap between all of the spark plugs, (see the emission label under the hood for the correct spark plug gap) and be certain that there is not any split-fire or multi-fire spark plugs installed in the engine, because those plugs will not work with an OBD-II system, and a random mis-fire is the least that they will cause if installed in an OBD-II controlled vehicle.
Aug 18, 2010 | 2001 Ford Taurus
Change the print size
Go to this website and download a free manual. Should tell you how to increase the font sizes:
http://www.ptouchdirect.com/ptouch/umpt1180.html
Dec 19, 2009 | Brother P-Touch 1180 Label Printer
Problem with Opera Mini 4
try upgrading it to opera mini 5. thats the one i am using and works perfectly fine http://www.opera.com/mini/next/
Oct 17, 2009 | Samsung S8300 Ultra Touch platinium-red...
How to dolad games
  1. Update your iPod Software to at least 3.xx version
    This is important as lower version of the software would not allow you to download any applications. You can do so from iTunes. Once you connect your iPod Touch or iPhone to the computer and start iTunes, it will tell you if there is a newer version of the software to upgrade. Just follow the instructions.
  2. Step 2 ** Restart your iPod/iPhone
    This step is just to reboot your iPod system to make sure the new software is in effect.
  3. Step 3 ** Download applications aka games
    Make sure your iPhone/iPod Touch is connected to the internet. On your iPod touch/iPhone home page, there will now be a link labeled: 'Apps store'. Select that link. Now, you are free to browse the many applications and games that iTunes has to offer. Some games are free while others may require you to pay. .
  4. Step 4 **Install the application aka game
    Once you have selected a game to install, tap the box that says, "free" in the right hand corner. It will then read, "Install". Tap the box again. Now, wait for the application to install on your home page.
Sep 25, 2009 | Digital Mind Corporation iQ Sound...
Mp4 player touch
  • ** Restart your iPod/iPhone
  • Step 3 ** Download applications aka games
  • Step 4 **Install the application aka game
  • hope this helps out a bit
    I would like to install bigger memorie in my latitude c610, how do i access the slots ?
    http://support.dell.com/support/edocs/systems/latd600/sm/upgrades.htm#999869
    Memory Module, Mini PCI Card, and Modules Dell™ Latitude™ D600 Service Manual
    bullet.gif Memory Module
    bullet.gif Mini PCI Card
    bullet.gif Modules
    Memory Module caution.gif CAUTION: Before working inside your Dell™ computer, read the safety instructions in your System Information Guide. caution.gif CAUTION: Toprevent static damage to components inside your computer, dischargestatic electricity from your body before you touch any of yourcomputer's electronic components. You can do so by touching anunpainted metal surface. note.gif NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    1. Follow the instructions in "Preparing to Work Inside the Computer."
    2. Turn the computer over, loosen the captive screw from the memory module cover, and lift the cover.
    upgrade7.jpg notice.gif NOTICE: To prevent damage to the memory module connector, do not use tools to spread the inner metal tabs that secure the memory module.
    1. If you are replacing a memory module, remove the existing module.
    notice.gif NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
      1. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      1. Remove the module from the connector.
    upgrad10.jpg notice.gif NOTICE: If you need to install memory modules in two connectors, install a memory module in the connector labeled "JDIM (Slot 1)" before you install a module in the connector labeled "JDIM2."
    1. Ground yourself and install the new memory module:
      1. Align the notch in the module with the slot in the center of the connector.
      1. Slide the edge of the module firmly into the connector, and rotate the module down until you feel a click. If you do not feel the click, remove the module and reinstall it.
    note.gif NOTE: If the memory module is not installed properly, the computer does not boot. No error message indicates this failure.
    1. Replace the cover and screw.
    notice.gif NOTICE: If the memory module cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    1. Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    2. Turn on the computer.
    As the computer boots, it detects the additional memory and automatically updates the system configuration information.
    Dec 30, 2008 | Dell Latitude C610 Notebook
    Internet connection problem
    • If newly installed, try uninstalling and reinstalling the device.
    • Once installed correctly, this error is unusual and may mean the device is faulty and needs to be replaced.
    • Some modems must be installed in a very precise order as dictated by the manufacturer. Be certain to closely follow the installation instructions. Consult the manufacturer's web site for a copy of the instructions or for an updated driver.
    Good luck!!!!!!!!!
    Dont forget to rate this post
    Aug 21, 2008 | Acer Aspire 5100 Notebook
    Maxtor Hard Drive Logo
    Top Maxtor Computers & Internet Experts
    Arora Singh
    Arora Singh
    Computer Links
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
