Carrier Weathermaker 8000 - furnace does not ignite
My heating system will run perfectly for about 24 hours, then suddenly the furnace will no longer ignite and the system will just continue to blow cold air. The LED light flashes one long and 3 short flashes (I don't have the codes), and the only way to get it working again is a reset (shut off the power to the system). Any ideas? Thanks
  • psingh2000 Jan 13, 2009
    I have the same since last two days
  • Anonymous Jan 22, 2009
    I have the same problem, changed the thermostat and cleaned the inside of the furnace (it was dusty in there) now I am going to change the heat sensor.
Having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Posted on Dec 20, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
1,190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
