Need a Schematic Stanley Garage Door Control board # 921-3316 or
921-3528.
Need a Schematic Stanley Garage Door Control board # 921-3316 or 921-3528.These are interchangeable boards.
Thank You
Bob
  • Anonymous Jan 19, 2009
    I just need the schematic of Garage Door for my home. I have to buy one portion.
2 Suggested Answers
odiegh
  • 81 Answers
SOURCE: I need a copy e-mailed
http://www.sentexparts.com/stanley_cb.htm
this site has repair parts for stanley boards and schematics contact them.
Posted on Dec 09, 2008
Control board component failure?
Wow. Blown IC!!!!!!!!!!!!!!!!
Best bet is to contact the manufacturer or get a hold of the schematic for the control board.
If unsuccessful you may be able to buy a replacement on the cheap on ebay and get parts.
Jul 12, 2015 | Building Materials
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
My garage door is not working is like not electricity
All you need is to use a multimeter to check the input voltage to the control board , ALso check the motor with a test to confirm the fault on the control board.
Only if you are tech savy can you be able to identify the faulty part as the control board circuit needs to be checked for the drive parameters.
If not get help to replace the control board or send it for repair to the dealer.
Aug 19, 2011 | liftmaster Garage Door Control Board...
Door opens by itself
Will likely need a little more info. I am presuming this is the wireless version since it's a Digi Code. However, my first thought is that the problem is not necessarily with the keypad. Most likely could be a programming issue. Have you tried to clear the memory on the Logic board on the Garage door opener and then re-program all of the openers, including the keypad?
Some Logic boards have a dedicated slot for one wireless Keypad that is made specifically for that brand of opener.
A helpful hint: When programming the keypad, have another person help you. Have them push the program button according to the programming instructions for your GDO Make.(Garage Door Opener)
Then you key in the required sequence for programming your keypad immediately after the programming button has been pressed. This reduces the amount of time the logic board wireless memory is in the learn state.
Sometimes stray radio transmissions operating at or near your openers frequency can inadvertantly be programmed into your openers logic board. Especially if there are other same manufacturers GDO units wireless remote transmitters in use within close proximity operating on the same frequency.
Another possible cause is in your hard-wired wall control button or wiring to it. There could be a short in the contacts causing the opener to operate, or a short in the wire to the wall control button. I've run into smashed wires that have had the outer insulation pierced and the metal staple shorts across both wires. (this is not good for the logic board, as it can damage sensitive circuitry on it. Causing more Costly repairs)
One way to isolate the issue is note when this occurs. Is it always the same time every day? Or is it completely random?
I hope these possible solutions help MASTER_TECH1
May 27, 2011 | Digi-Code Digi Code 5202 Garage Door...
Help, our neighbors can open our garage door with their remote, but not vice versa. Want to reset the code on the garage door motor, but have no manual...thank you for any help!
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jan 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I'm looking for the circuit board schematic for a 412LM Receiver. One of the resisters has turned black.
If you are looking for a schematic for a garage door opener receiver there are none available.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
Jul 12, 2008 | Electrical Supplies
Computers & Internet Logo
431 people viewed this question
David Payne
David Payne
