Which speakers can I use?
Recently I bought an old pioneer system without speakers. The amplifier is an 'a-z370'. I believe it is a 4 channel 300w amplifier but not knowing anything about systems or speakers this means nothing to me (sorry for my ignorance!!). As I have purchased an old system I am only looking to purchase either quality used speakers or inexpensive new that will do justice to my system.
I have been told the watts is less important than the ohms? I am unsure what the ohms is for my system??
ANY help or advise would be appreciated!
Many Thanks.
  • Audio Player... Master
  • 5,348 Answers
You can use any wattage speakers as long as they are not less than the watts from your amp. However you can still use lower wattage speakers as long as you don't turn up the volume full or two loud! Otherwise your damage the speaker.
HOWEVER you must get the ohms matched up right. You must never connect any speaker with a low Ohm to a high rated amp. Or you will blow the output stage transistors or IC.
Most Amps are 8 ohms, so you could connect an 8 or 16 etc, but not a 4 ohm.
Posted on Jan 27, 2009
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
Total Power Bridged in 2 or 4 Ohms ?
Nice amp the specs say the following:
4 Channel 100W x 4 (4 Ohm)
4 Channel 150W x 4 (2 Ohm)
2ch Bridge 300W x 2 (4 Ohm)
But.... it tends to go into protection quite fast so i wouldn't go too low with speaker impedance.
Dec 28, 2010 | DHD NTX-3106 Car Audio Amplifier
Pioneer SA100 integrated - low, distorted output
At this point, I would be looking at the main power suply for the final output stage. You may be attempting to drive the output with the driver section rather than the final amp stage. The center pin of the output transistors should have B+/B- on them. Measure that to ground and report the value here.
Dan
Jul 12, 2010 | Pioneer A35R 2-Channel Amplifier
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Sibilant output from Pioneer VSX 1018 AH-S
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
May 09, 2017 | Pioneer VSX-1015TXK Receiver
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
No audio - Pioneer Amplifier A-Z370
I experienced something similar.
Symptom: After use the sound cuts out together with a mechanical click (relay sound). Turning off and waiting a bit before powering on, tends to 'fix' it, but the sound cuts out in the same way after a while.
The click led me to the little relay board inside. Inspection of the solder joints showed that a few were 'broken' ("cold soldered"). This was right below a high-wattage resistor, possibly the cause of the stress causing these random disconnects.
Fix: Resolder the joints.
Jan 02, 2008 | Audio Players & Recorders
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
107 people viewed this question
 Grubhead
Grubhead
