Question about PC Chips A33G (V1.0) Motherboard
REBOOT WHEN CHECKING NVRAM
HELLO, MY PROBLEM IS MY COMPUTER REBOOT WHEN CHECKING NVRAM
PLEASE HELP ME
  • 144 Answers
Check for faulty caps on your mobo or power supply. They probably gone dry/leaky..
Posted on Dec 10, 2008
BIOS NVRAM checking - not passed
I have had even new sticks of ram not work in one machine, but are fine in another. Put the old ram back in and make sure everything works like you want, then try the ram again. If they are still giving problems, unfortunately it looks like even more ram is your solution.
Dec 23, 2017 | Toshiba Satellite Computers & Internet
Reboot Printer
the power cord  may  be  loose.....
or the  usb  connection...........
did u try checking  for those
Oct 23, 2008 | Xerox Phaser 7750DN Laser Printer
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Checking Nvram
You could have had a corrupted update. Do you have the CD that came with the computer? There is a BIOS restore utility on it. Download the 1st BIOS version from the website and see if you get the same results.
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Advice phaser 7300dn appear 10: eeprom ,help me please!
The only thing you can do is attempt a reboot and hope for the best, otherwise call out an engineer to repair it! Or you could try and NVRAM reset but I'm not sure if that will work and be careful because you will set the machine to factory settings and may have to do a colour calibration all over again. Let me know how it goes.
Resetting all settings to default (NVRAM)
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Dec 11, 2008 | Xerox Phaser 7300DN Laser Printer
Like cmos battery problem.... checking nvram
That is what you are supposed to do move jumper 30 seconds and replace back to original
your BIOS should be set to default check that you have correct ram inserted into M/board
Aug 16, 2008 | EliteGroup P4VMM2 Motherboard
P4VMM2 "Checking NVRAM"
Do you know where the lithium battery is located on that motherboard?
Replace it and reset your BIOS.
Jun 11, 2008 | EliteGroup P4VMM2 Motherboard
One Beep after Checking NVRAM...Update OK
The Computer generates 1 beep. to state that the computer has set itself up properly, without errors. Depending on the bios manufacturer. i.e Pheonix or AMI et,c.
As long as your system is running fine with no crashes or errors.
Then this seems perfectly normal.
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
Nvram
Hi, This message "Checking NVRam" is part of the BIOS/CMOS POST even before Windows loads up. Offhand two things you can try: 1. Do a CMOS reset by temporarily moving the jumper near the battery to the opposite pair or by removing the Lithium battery for a couple of minutes or as prescribed by your motherboard's user manual; 2. If #1 is a no go, perhaps you should consider flashing your BIOS. If neither works out, it is possible that you have a hardware/motherboard problem and would require replacement. Hope this be of some help/idea. Post back with your motherboard brand/model, how things turn up or should you need further information. Good luck and kind regards.
Sep 14, 2007 | Computers & Internet
PC Chips A33G (V1.0) Motherboard Logo
302 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
