Question about Microwave Ovens
I have a NNH964BF inverter type panasonic microwave. Once we press the start button, smoke starts coming from the bottom vents of microwave body and it stops after 6/7 seconds.
  • Gus May 11, 2010
    This an electronic fault either with the inverter module itself, or it may be a fault in the RF shielding around the magnetron unit.
    Provided you are savy and sensible you can remove the cover to inspect.
    REMOVE POwer and allow to sit idle for a good 20mins before removing hte top cover.
    IMPORTANT 5000v can be present inside the case even with hte power off.
    All your looking for at this point is evidence of where the smoke came from.. DONT TOUCH ANYTHING with fingers, keep one hand behind back or in pocket if you must reach inside. And under no circumstances apply power with the case removed, a faulty mwave can excite water molecules in the human body and cook an eyeball quite quickly. :o)
    It may also be a seized turntable motor that can smoke and overload. I suspect the smoke is from the main inverter module, (Circuit board item with copper coils bolted to the base of unit.)
    you can replace these yourself, but you will need to hunt down a spare.
    But as mentioned like CRT telvisions LETHAL voltages exist inside these units so do be careful. :o)
  • Microwave Ovens Master
  • 9,086 Answers
If it stops after 7 seconds, it has a problem with the inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
But if you or a friend do want to look into it, follow the safety warnings in Smogoose's Clarification Request and these safety tips.
Unless you have a lot of troubleshooting experience, you should replace the whole inverter as a unit.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
Posted on Dec 13, 2008
HOW TO reset panasonic microwave
check your safety interlock door switch..
Jul 22, 2014 | Panasonic NN-H965 Microwave Oven
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Microwave starts then quits, turntable doen't turn
At this time we recommend you locate an authorized service center using the below link. www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic Microwave Ovens
We put a plastic jar with a very small piece of foil on the rim and the microwave started to smoke. it might have run 30 seconds before we noticed it making a funny noise. it is a 1200 watt inverter
Hello Dwight,
You may have damaged the microwave. Since the oven cavity is a tuned cavity, introducing metal into it can wreck havoc on the magnetron (microwave generator itself).
Did you happen to notice if the smoke was from the plastic jar (plastic heating up from the high temp of the foil ring), or if it was the actual microwave smoking (and not blowing smoke out of the oven cavity from the plastic jar)?
Sep 14, 2010 | Panasonic MCM INVERTER
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Shuts off after approx 5 - 7 sec. some smoke
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
In Canada, you can find an authorized Panasonic servicer here.
If you prefer to replace the inverter yourself, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 15, 2010 | Panasonic NN-S954WF Microwave Oven
Its locked
mine just did this too, its the inverter type. I finally found the instructions. It goes in lock when start is pressed 3 times. It can be unlocked by pressing the stop/reset button 3 times, the clock should come back up in the display window. Good luck
Jul 07, 2009 | Panasonic NN-T888S Convection/Microwave...
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Microwave Problems
It may be as simple as a door switch, but it's usually a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on the high voltage section.
If you were to opt for service, I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 06, 2008 | Microwave Ovens
Faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 24, 2007 | Panasonic NN-T655SF Microwave Oven
Microwave Ovens Logo
150 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
