Question about Canon iR 2016i Black and White Copier
I need to default scan to PDF on a Canon ir2016i
  • anubhav2010 Feb 19, 2009
    how to scan in canon ir2016
  • Carlos Perez
    Carlos Perez May 11, 2010
    do you have U-send?
Tem eror
7
Posted on Sep 29, 2009
What I require is to scan a document on a Canon 2016i printer to save as a pdf. The default is current set to TIFF and i cant seem to find the answer easily in the manual.
You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 29, 2011 | Canon Office Equipment & Supplies
Hi How do I get my Canon iR2016i to automatically
You need to install a PDF printer driver on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Jun 29, 2011 | Canon iR 2020i Laser Printer
I wanted to print and scanned on canon ir2016i directly from my computer. how can i do that? how can i able the printer identify my IP?
if u are on network then u can simply enter the ip address in system settings tab in additional functions.then load the driver ,it will autorun after detecting machine. the scanner is network scanner and will work only in network.
if u are single pc user then load the drive and connect the machine through usb printer port when the driver asks to connect. hola
May 25, 2011 | Canon iR 2016i Black and White Copier
SETUP OF NETWORK PRINTER IR2016I
Install network scan gear on all PCs and make necessary settings ( IP, discover,... ), it should work as PULL scanner.
May 29, 2010 | Canon iR 2016i Black and White Copier
Canon MX860 Scan to PDF 10 times bigger than source PDF file
My suggestion would be to check your scanning software and change the quality of the scan. If it is a document - you really don't need a quality above 200 - maybe even lower if it's available. I would guess your scanning software is defaulting to a much higher quality.
Sep 21, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Default Settings for Canon Imagerunner 3025 Scanning
You will find those settings in your scanning software on your computer, since all of them are different, there is no one right answer. Some you have to choose each time you start a new job or document.
Jul 22, 2009 | Office Equipment & Supplies
Scan to pdf on imagerunner 5075
Unfortunately, you can't do it remotely. You have to do it at the machine. Just hit the "additional functions" button, go into "communication settings", then "TX settings" on the left, then "edit standard send settings". This is where you would set your default resolution and file type.
Mar 11, 2009 | Canon imageRUNNER 5000 Copier
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Canon iR 2016i Black and White Copier Logo
210 people viewed this question
old marine
old marine
