Question about Canon Rebel XT / EOS 350D Digital Camera
Err99 Can you please let me know where the small button battery is on Canon 350D as I need to remove it. Kind Regards Markus Fischer
  • 2,039 Answers
The manual is not much help on this one. The battery is a CR2016, and should be in a holder accessible from the battery compartment. Look along the sides and see if there is a panel that you can catch with your fingernail and remove from the camera. Make sure you put the replacement battery in the same orientation (+ / -) as the one you take out.
Posted on Dec 10, 2008
I have a canon 350D and Problem is err99.when I try to snap at wide angle ,it displays err99.
The most common issue that brings about the Err99 is an issue between the lens and the body, but it could actually come from a variety of problems.
Two things you could do:
1) Clean the contact points on both the Camera and your lens (be careful not to get any dirt into your camera - best to hold it in the air facing down when you are cleaning it)
2) Remove your batteries and memory cards (most cameras also have a small battery for the Date/Time), turn the switch on for a minute or so, then turn it off and replace the batteries and memory cards
I know the original 300D and even the 350D had a very limited shutter lifespan, if you've had the camera for a long while and have taken many pictures it is possible that this may be related to your issue.
Aug 30, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have worked all day, thinking Ive recorded the event i covered. In the process I discovered this Error 99. My Canon EOS 350D could only take a successful shop when I zoom an object and go far to make...
If you get err99 with lens then lens diapharm unit goes wrong and its giving er99.
if you getting with body and there is coupleof possiblities.
please descride brifly your camera fault
how and when you geting err99
Aug 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
After showing pictures camera Stucked
Hello
Please be so kind to let me know if your camrea only work in image view mode, but if you put it on the capture setting it turns off.
Kind regards
Andrea
May 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My canon rebel gave an error 99 and then lost all power. It won't power even with a fresh battery.
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
ERR 99 DURING SHOOTING
Hello :
The Canon Error 99 is a message that pops up when there is a contact issue between a lens and the body of the camera. Also it represents a bad battery, defective storage card and anything else the software doesn’t seem to like. It’s basically a catch all error message a bit like the familiar windows BSOD.
Up till now the current procedure to get rid of the Canon Error 99 was to take the battery out and put it back in. Canon have now created firmware numbered 1.0.3 that aims to tackle the Err99 message .
Firmware 1.0.3 fixes Canon Error 99 1. Corrects a phenomenon in which an image becomes overexposed when C.Fn.II-3 Highlight tone priority is set to “1′ together with other camera settings. (This correction has already been incorporated in the Version 1.0.2 and later firmware.
2. Corrects a rare phenomenon in which “busy” blinks on the camera’s display panel and the shutter cannot be released due to the timing of battery installation.
3. Corrects a rare phenomenon in which “Err 99′ appears on the camera’s display panel and LCD monitor and the shutter cannot be released due to the timing of pressing the shutter button.
You can download this update from this link : Firmware 1.0.3
good luck .
Don't forget to rate if useful please !
Apr 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
ERR99 and not taking any photos.
So you're saying the camera works fine with another lens, just not with the 18-55. Try cleaning the contacts where the lens and the camera body meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
