Question about Orion VR213 VHS VCR
Taping from surveillence cameras
I have a surveillence cameras and a orion vcr set up to record. It did fine the first time but when we tried to tape over the vhs tapes after viewing we can't get it to record. What are we doing wrong and is there anyway to reset the vcr we don't have a remote and can't tell which channel its set to. Help we need to be recording activity in our 24 hour gym.
    Genius:
  • 1,199 Answers
The vcr has to be set to moniter the camera!...buy a cheap universal remote and push monitor in the menu screen!
Posted on Dec 10, 2008
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
The video machine bleeps continually and shows a message E-3
I think the E3 error code indicates an error with the tape drive mechanism. If it ate a tape, this would indeed be the problem. Time Lapse VCR's are not very popular anymore, everything has gone to digital. It would most likely cost you more to fix that VCR than to switch out to a digital recorder.
Other advantages are -
No tape to change
Very good recorded image quality compared to VCR
Most digital units have capability for remote viewing over the internet
You can set the unit to "alert" you if there is movement in the garden
Sep 25, 2008 | Home Security
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Convert miniDV to VHS
You use the mini to triple RCA cable with the camera and go into the menu and make sure you are on A/v out instead of headphones. You just hit play on the camera and record on the VCR and Whala, it's done.
Videoteacher
Nov 26, 2007 | Canon ZR70MC Mini DV Digital Camcorder
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Apr 24, 2007 | Orion VR0419 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Orion VR213 VHS VCR Logo
56 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
