Question about IBM ThinkPad X21 2662 Notebook
IBM THINKPAD X21
Question, I'm having a problem with my laptop. It won't turn on when I press the power button. But when i plug the charger the standby light (green) comes on, and the battery light (yellow) comes on but nothing else. The laptop is an IBM Thinkpad X21. Thanks in advance!
Regards,
    Novelist:
  • 166 Answers
Sir your problem is very common and only have two possibilites :
  1. Your RAM is faulty and you need to replace it. Its cheap n simple solution.
  2. Also it may be a problem in any component of *********** board and you need to repair that specific module.
Rate me properly if i was helpful to you.
With Regards,
Shyny Saxena
Posted on Jul 21, 2009
Power problem
Most units will operate with battery removed and charger attached--try that first to see if battery is the issue or not.
Jun 07, 2012 | IBM ThinkPad X21 2662 Notebook
Would like to reset my ibm laptop it says my mircosoft online service is temporarily unavailable and my laptop is slower than ever
Hi and welcome to Fixya1
To reset the machine back to the factory settings, just follow these steps:
    • 1 Shutdown your machine and make sure that the charger is plugged in before doing the reset. Turn on the machine.
    • 2 Press the blue Access IBM button on your ThinkPad keyboard at the screen prompt. The screen prompt reads "To interrupt normal startup, press the blue Access IBM button." This interrupts the Windows reboot process.
    • 3 Double click "Recover to Factory Contents" at the Access IBM predesktop menu.
    • 4 Follow the recovery wizard prompts to initiate the factory restoration process. Your ThinkPad will automatically reboot upon completion.
Hope this helps!
Takasashi
Jul 19, 2011 | IBM ThinkPad R40 2722 Notebook
My ibm thinkpad from the year 2000 wont turn on. i have connected the adapter and put the battery. i press the button to turn it on but the laptop wont turn on
1st thing you need to do is to make sure the adapter is working.
check to see if any LED indicator lights up when you connect the charger.
if none of the indicators light up with the charger plugged in, you may need to consider replacing your charger/adapter.
however if the indicator come on, then it is most probably a problem with your power/on switch (at the least) or a problem with your motherboard (at the most)
Mar 31, 2011 | IBM ThinkPad T21 Notebook
How do i turn on ibm thinkpad. i press power button but nothing appears on the screen
Hi annemariemil,
you may wanna try to do a power drain by removing battery and unplug everything connected to your pc.then press the power button for 1 minute.
then after that plug back in the charger but not the battery yet then try to turn it on
hope it works
Mar 26, 2011 | Computers & Internet
I forget my password .my laptop is IBM thinkpad X21 type2662. pls help me
http://hotfile.com/dl/94523441/9f351b8/Hirens_BootCD_13.0__9Down.COM.rar.html
BY USING THIS LINK YOUWILL GET PASSWORD BREAKING SOFT WARE DOWN LOAD IT AND BURN IT IN THE CD.INSERT IT IN YOUR PC OR LAPTOP .RESTART YOUR SYSTEM AND PRESS ANY KEY TO BOOT FROM CD .WHEN THE CD STARTS BOOTING FOLLOW THE INSTRUCTIONS TO BREAK YOUR SYSTEM PASWORD.AFTER BREAKING YOUR PASSWORD WIIL BE BLANK.NO DATA LOSS WILL HAPPEN YOU CAN EASILY LOGIN TO YOUR SYSTEM AND YOU CAN SET NEW PASSWORD ALSO.
PLEASE GIVE THE VOTES TO IMPROVE MY SOLVING SKILLS
Feb 16, 2011 | IBM ThinkPad X21 2662 Notebook
I forgot the password
Hard Disk Password
The hard-disk password (HDP) protects the data on your removable hard disk drive from being accessed by unauthorized persons.
Supervisor Password
The supervisor password protects the system information in Easy-Setup from being changed by unauthorized persons.
How to Reset an IBM ThinkPad Power On Password using Software
If you can boot the IBM ThinkPad, KeyMaker will recover the messagebox_info.png BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password messagebox_info.png icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart.
Oct 26, 2010 | IBM ThinkPad X21 2662 Notebook
IBM ThinkPad X21 2662 Notebook Logo
169 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
