Question about Slant Fin Warm Mist GF-210 Humidifier
Er3--is this an error message?
I bought this humidifier a couple of weeks ago, and now the digital panel just reads "Er3" instead of the humidity level, Hi/Lo etc. I cannot find in the accompanying manual what this means. Unplugging it and plugging it back in did not work. Then I tried emptying it out and refilling--it briefly went back to normal display but then back to the Er3 again. What do I do?
  • Jason Jan 21, 2008
    Has anyone found a solution to this problem? Weird thing is, the humidifer still works although you cant adjust setting. But since humidifiers usually overpromise anyways wth regard to square footage, keeping it on high (which I think is where its stuck during Er3) isnt such a problem. Still, this sucks as I just bought it a month ago!
  • Citycat Jan 23, 2008
    I have the same issue. I called Slant/Fin cust service, and this is what they said: ER3 is an INTERNAL ERROR, and can not be fixed by the consumer. You must send your unit back to them with the following information....
    Name, Address, Tel #, model #, length of ownership, and that you are getting an ER3 message.
    Send the unit to:
    KAZ Returns
    4755 Southpoint Dr
    Memphis, TN 38118
    You can call cust service at 800 477-0457.
    I owned my unit less than 3 weeks before this happened. I have a GF-211-D.
  • 944 Answers
This sounds like the float switch may be stuck - giving an error message - usually these are not too hard to unstick - it is often a cleaning issue - the manual should show you where the float switch is and how to check it, but if the error message is not listed in the manual, if you are sure it is the correct manual then I would expect it to be a technicians job, else they would list the error message. Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: info@kaz.com also worth a look is: http://www.achooallergy.com/slantfin-ope... seems to be best forum for humidifier stuff Hope this helps :)
Posted on Mar 01, 2007
What are the benefits of buying a Humidifier?
There are many health benefits of using humidifier at home, it increase the indoor humidity levels in winter. Which make air dry and moisture is essential for preventing nose bleeds and relieving dry cold, allergy and asthma symptoms etc.
It also good for children skin and pets, you should use cool mist humidifiers for safe environment for your children.
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Jul 31, 2015 | Humidifiers
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
If i hook my Aprilaire 400 Manual (not auto/digital) humidifier up straight to a 24v wall outlet instead of to the furnace, will it still work correctly? Or does it need to be powered by the furnace to...
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier.
It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
Jan 31, 2013 | Aprilaire 400 Humidifier
We left the humidifier with the water tank half full for a few months, then realized, cleaned veerything up with vinaager as for instruction manual, refilled with water, but we turned on the humidifier is...
Brother, I think you're OK here. I run a couple in my shop, both cheap from Walgreen's, and I'd be ruining the suckers once a week if they didn't have auto-shut-off. Your's should too. Sounds defective.
Dec 12, 2017 | Vicks V5100N Humidifier
He265a,b to much water flowing through and not getting the humidity . why is there so much flow
Don't know why so much water. May be able to adjust by turning down valve tap. Turn unit on and you should be able to hear water pressure decrease. Make sure damper in 6" pipe is open so humidified air will get through system. When very cold humidities are lower. Also must hum. mfgs. suggest connecting with hot water instead of cold (vaporizes faster) don't know which you have
Jan 22, 2011 | Honeywell HE220A1019 Whole House...
The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Jan 14, 2011 | Vicks V4500 1 Gallon Humidifier
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Hunter 34357 displays LO instead of number in humidistat
I have the same problem. And nothing in the instructions. Searching for a solution now.
Feb 05, 2010 | Hunter 34357 Humidifier
Slant Fin Warm Mist GF-210 Humidifier Logo
275 people viewed this question
Top Slant Fin Humidifiers Experts
Marvin
Marvin
James Gettemy
Tom Chichester
Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
