Question about Acer AL2017 20" LCD Monitor
Acer AL2017 Monitor
I see from a previous post that you found some bad Caps on the Inverter/ Backlight driver of this monitor. I assume that they are at the output of hte Backlight. Can you tell me what value can be used as replacements?
Duane
  • abyssnolf May 09, 2009
    I replaced the 1000uf and 220uf capacitors and now the screen comes on, but the backlighting quickly dims and disappears. Then there's a hissing noise as the backlight turns off, followed by a repeated attempt. After the second attempt, the monitor turns itself off.
    Any ideas what this might be?
    Brigadier General:
  • 5,158 Answers
You will need 3 or 4 ( forget now) 220 uf 25 volt and two 1000 uf 25 volt .... just finished putting this one back together and it's great.
Posted on Apr 08, 2009
  • Roberta Smith
    Roberta Smith Apr 08, 2009
    please take a moment to rate this solution... thanks
Acer screen is completely black
There are more than one version of this model.
http://s807.photobucket.com/albums/yy352/budm/ACER/ACER%20AL2017%20Abd/
http://s807.photobucket.com/albums/yy352/budm/ACER/ACER%20AL2017%20BMD/
You need to look for bad caps with bulging/leaking tops, blown fuses, shorted MOSFET, etc.
Please read my guide to understand more:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 03, 2011 | Acer AL2017 20" LCD Monitor
My monitor will be black when I start up my dator. I have to turn my monitor on and off several times before I can get it to work properly.
Look for bad caps as shown in my albums here:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 28, 2011 | Acer AL2017 20" LCD Monitor
THIS MONITOR COMES ON FOR A FEW SECONDS THEN GOES OFF LCD BACKLIGHT TURNS OFF
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=AL2017&kategoria=monitor&kat2=all
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor troubleshooting guide:
Dec 03, 2010 | Acer AL2017 20" LCD Monitor
I've just had an Acer AL2017 apart that someone left out in the rubbish, assuming that it wouldn't work, i've taken it apart and seems to be ok, nothing burned out no knocks and scrapes. Standby light is...
Please look at my pictures of failed monitors, read the guide to understand how monitors work, learn about bad caps, bad solder joints, etc.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL2017%20Abd/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 11, 2010 | Acer AL2017 20" LCD Monitor
My monitor was working fine but now it won't turn on. Nothing was happening when it suddenly went off.The light is also not on and I have tried a few different power cables and plugs. It is an acer monitor...
Nost failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 24, 2010 | Acer AL2017 20" LCD Monitor
Monitor shows acer then turns off come back on shows acer then off again
The sceen will not stay lit can be caused by bad caps (bulging top/seal) in the power supply, failure in the backlight inverter circuits (bad transistors, transformers), or bad lamps (bad solder connection), bad solder connections. You need to open it up and inspect the inside, post backwhat you see so we can guide you further. See example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Acer AL1706AB LCD Monitor
NO LIGHT ON SRCEEN
This model AL2017 20" Acer monitor is known for having a bad power inverter board. The capacitors go bad, which causes the backlight to completely stop working or flicker intermittently. If you feel like you are electronically and mechanically inclined the board is easily replaced. Search ebay for AL2017 Power Board -- its about 15 bucks plus shipping.
Feb 13, 2010 | Acer AL2017 20" LCD Monitor
White Screen
check for any swollen caps on the power supply/inverter board and the LCD driver board.
Feb 03, 2010 | Acer AL2017 20" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
669 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
