Question about SanDisk Sansa MP3 Player
Trouble with expanded memory
I purchased an 8 GB SanDisk Micro card and when I insert it into my Sansa Express it won't recognize that it exists. The Sansa Express will slow down like it's searching a larger area but there seems to be no way to get to the expanded memory. What is wrong??
Thank you
Jackie :)
  • 728 Answers
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Posted on Apr 04, 2009
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
How to expand my memory and what type of memory card to buy
It will certainly take a 2GB microSD card.
This link on Sandisk forums tells how to check if you have a version 2 that will take a 4GB.
forums.sandisk.com/t5/Sansa-e200-series/Sansa-e250-compatible-with-4-GB-Micro-SD-Card
Where to buy one? My local supermarket has them, or you could check a camera store, or even office supplies. as well as the usual computer or electronics stores.
Feb 11, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
I inserted a 2gb micro sd card into my 4gb sansa fuze for more memory and it's still saying I don't have enough space on it when I go to add a song off of limewire
Inserting a microSD card into the Sansa does nto magically expand its internal memory. The card is a separate chunk of memory. You can move some songs from the internal memory to the card to free up some internal memory. Or you can add the new song to the card.
May 15, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa MP3 Player Logo
241 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
