When starting up Windows XP - the process stops and I get the message C0000135 application failed because user32.dll wasnot found. I have tried to start in safe mode but the same problem re-appears. ie: computer will not start in safe mode. Any suggestions, please.
  • 38 Answers
I've just seen this on another users pc, here is how i solved it:
Start from your xp disk (recovery disk that you got with your machine or retail copy of xp), when prompted go into recovery mode (press r at the menu)
when in the recovery mode go to c:\windows\$NtServicePackUninstall$ and type
copy user32.dll c:\windows\system32\
then type 'exit' without quotes to reboot
your system will now boot up fine
(note there may be a copy of the user32.dll file in c:\windows\system32\dllcache\ as well)
Posted on Dec 10, 2008
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
Emachines T4010 won't start up, says image checksum, and that an image is corrupted
Receiving a bad image checksum error message when upgrading a computer to Windows XP means that a Windows system file such as user32.dll is damaged. This error occurs when any damaged system file is encountered that isn't overwritten during Setup. The repair process for this error involves voiding the damaged dynamic link library file from the DOS command line prompt and replacing it with a new copy from the Windows XP disk.
Insert a clean Microsoft Windows Millennium Edition (ME) or Microsoft Windows 98 Edition startup disk into the computer, and hold the reset button on the front of the computer until the system commences rebooting. Navigate the Windows startup menu with the keyboard's directional keys and select 'Start Computer with CD-ROM Support'. Hit "Enter" to continue. Write down your CD-ROM's drive letter on a piece of paper. At the command prompt, type "Drive:" without quotes (Drive should be replaced with the drive letter on which Windows is installed), and press "Enter." Type "cd windows\system32" without quotes, and press "Enter." Type "ren user32.dll user32.old" without quotes and again press "Enter." This renames your damaged user32.dll file so it is not recognized by the system, but still physically exists as a backup if needed in the future. Eject the Windows ME or 98 disk, and insert the Windows XP disk. At the command prompt, type "extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dll" without quotes, replacing CDROMDrive with the CD-ROM's drive letter that you made a note of earlier, and replacing Drive with the system's drive letter on which Windows is installed. Hit "Enter" to execute the command. This process extracts a new copy of the user32.dll file to your hard disk, from the Windows XP CD. The new file will be found in the Windows/System32 directory. Restart the system by holding the reset button on the front of the tower until reboot commences.
Jan 03, 2013 | Computers & Internet
Stop: C0000135 {unable to locate component}
ok if is win xp just run the xp cd and choose repair that should solve it
Aug 31, 2009 | Dell Dimension 2400 PC Desktop
Dell Vostro will not boot up
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
May 18, 2009 | Dell Vostro 1700 Notebook
My IBM thinkpad wont start
first of all we need to know what operating system ur using......
iam presuming ur using XP....
have you tried copying user32.dll back to the c:\Windows\System32 directory from the XP disk, another computer, or parallel install of XP?
If you can get to Safe Mode or Even Safe Mode Command Prompt you may aslo be able to run "sfc /scannow" at the prompt and get Windows to check all of it's system drivers and replace any that are found corrupted.
if ur not able to access through safe mode
if you are making it to the boot menu options you may try "Last Known Good Configuration" or something like that... if you are unable to get that to work either then you best bet is probably to try and run the Recovery Console from the XP CD. If that doesn't work you could try messing around with either booting XP Pre from a boot CD and copying files to wherever you need, or installing a parallel copy of XP, booting to that and copying files to your old copy. You can also try installing over the top of the existing XP but that would be my last effort as it could permanently destroy data you might be trying to keep.
if it still doesnt work
I think you may be looking at a re-install if your system is that messed up.
hope i was able to help
if u felt so... dont forget to rate my service
thank you
have a nice day
May 01, 2009 | IBM ThinkPad T40 2373 Notebook
Blue screen c0000135 user32.dll not found
Did you install something or Edit something prior to this happening? How old is the laptop, if it is more than 3 years old then replace the hard drive.
Feb 01, 2009 | Computers & Internet
Dll user32.dll problem
Certain programs may not start after you install security update 925902 (MS07-017) and security update 928843 (MS07-008) on a computer that is running Microsoft Windows XP with Service Pack 2 (SP2). Additionally, you may receive an error message that resembles the following: application_executable_name - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
User32.dll error message
I suggest you go do a google search and look for spybot, it has a registry FIX and scanner built in that will successfully immunize your system from hijacking website cookies and trojans, and bring your system to as close as functional as possible, then go to download.com and grab AVG anti-virus, do a complete scan, delete everything that shows, or quarantine after a successfull complete system scan. Be sure to reboot after EACH successfull AVG scan, as the program cannot delete high memory cookies or hijackers, and can only do at a system start up, before these programs go into high memory(RAM bits and bytes that users cant touch when a system is operational and fully booted up).
I hope this helps you a bunch, I have had the same DLL problems with my father's PC being hijacked from REGISTRY EDITOR cookies and trojans, mostly harmless key coder programs to watch your surfing.
If this does not help, then you are past repair on my levels and require a reinstall of the operation system and clean format of your drive. Attempt to backup all your important files to a DVD or TWO so that you can recover.
LAST RESORT is to partition the drive that you are using, and set up a system restore for your windows on this partition, if you EVER get this type of error again, if its not a corrupted video card or system driver, you can restore your PC on a clean backed up system, and retain all of your files and documents.
Just a suggestion, most will find this usefull..
ManOWar
Aug 09, 2008 | Dell Dimension 2400 PC Desktop
Stop Error: c0000221
This issue may occur if any of the following conditions exist: • A damaged file exists in the folder in which Windows is installed, and this file is not overwritten during Setup. For example, if you receive the error message that references the User32.dll file, the User32.dll file may be damaged. • One or more of the random access memory (RAM) modules that are installed in your computer is faulty, or the RAM configuration is incompatible
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this behavior, use one of the following methods. Method 1: Extract a New Copy of the User32.dll File from the Windows XP CD loadTOCNode(2, 'resolution'); Extract a new copy of the User32.dll file from the Windows XP CD to the drive:\Windows\System32 folder on your hard disk, where drive is the drive on which Windows is installed: 1. Insert a Microsoft Windows Millennium Edition (Me) or Microsoft Windows 98 Startup disk into your computer, and then restart the computer.
NOTE: For additional information about what to do if you do not have a Windows Millennium Edition or Windows 98 Startup disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 186300 (http://support.microsoft.com/kb/186300/EN-US/) How to Create a Windows 98 Startup Disk from MS-DOS 267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me 2. When the Windows Startup menu appears, use the ARROW keys to select Start Computer with CD-ROM Support, and then press ENTER. 3. Make a note of the drive letter of your CD-ROM drive. 4. Rename the User32.dll file to User32.old. To do so, type the following lines at the command prompt, pressing ENTER after each line, where Drive is the drive on which Windows is installed: Drive:
cd windows\system32
ren user32.dll user32.old 5. Insert the Windows XP CD into your CD-ROM or DVD-ROM drive. 6. Extract a new copy of the User32.dll file from the Windows XP CD to the Windows\System32 folder on your hard disk. To do so, type the following lines at a command prompt, pressing ENTER after each line, where CDROMDrive is the drive letter of the CD-ROM or DVD-ROM drive that contains the Windows XP CD-ROM, and Drive is the drive on which Windows is installed: a:
extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dllFor example, if your CD-ROM is drive E and Windows is installed on drive C, type extract e:\i386\user32.dl_ c:\windows\system32\user32.dll, and then press ENTER. 7. Remove the Windows 98 or Windows Millennium Edition startup disk from your computer, and then restart the computer.
Method 2: Remove or Replace the Faulty RAM loadTOCNode(2, 'resolution'); Remove the memory modules that are installed in your computer, leaving enough RAM for the computer to start and run Windows. Restart the computer, and then run Setup again.
For additional information about Windows XP RAM requirements, click the following article number to view the article in the Microsoft Knowledge Base: 314865 (http://support.microsoft.com/kb/314865/EN-US/) System Requirements for Windows XP Operating Systems If the issue is not resolved, remove a different memory module. To identify the specific memory module that is not working correctly, you may have to restart your computer more than one time.
For information about how to add and remove RAM to the computer, contact the manufacturer of the computer, or view the documentation that is included with your computer.
Method 3: Install Windows to a Different Folder loadTOCNode(2, 'resolution'); NOTE: Before you install Windows to a different folder, first try the troubleshooting procedures in the following article in the Microsoft Knowledge Base: 310064 (http://support.microsoft.com/kb/310064/EN-US/) HOW TO: Troubleshoot Windows XP Setup Problems During Installation When You Upgrade from Windows 98 or Windows Me If the issue is not resolved by using the troubleshooting procedures in 310064, install Windows to a different folder. For more information about how to do this, see the "Installing to a New Folder" section of the following article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/) HOW TO: Install Windows XP MORE INFORMATION loadTOCNode(1, 'moreinformation'); For additional information about how to troubleshoot "STOP: C0000221 error messages", click the article number below to view the article in the Microsoft Knowledge Base: 314474 (http://support.microsoft.com/kb/314474/EN-US/) "STOP: C0000221 Unknown Hard Error" or "STOP: C0000221 STATUS_IMAGE_ CHECKSUM_MISMATCH" Error Message Occurs For additional information about upgrading to Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 316639 (http://support.microsoft.com/kb/316639/EN-US/) HOW TO: Prepare to Upgrade Windows 98 or Windows Millennium Edition to Windows XP For additional information about how to troubleshoot startup problems in Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 308041 (http://support.microsoft.com/kb/308041/EN-US/) Resources for Troubleshooting Startup Problems in Windows XP For additional information about Windows XP Setup, click the article numbers below to view the articles in the Microsoft Knowledge Base: 306824 (http://support.microsoft.com/kb/306824/EN-US/) Release Notes for Windows XP Setup Contained in the Home.txt File 286463 (http://support.microsoft.com/kb/286463/EN-US/) Release Notes for Windows XP Setup Contained in the Pro.txt File 286647 (http://support.microsoft.com/kb/286647/EN-US/) Windows XP Read1st.txt File Contents For information about how to contact your hardware manufacturer, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base: 65416 (http://support.microsoft.com/kb/65416/EN-US/) Hardware and Software Third-Party Vendor Contact List, A-K
60781 (http://support.microsoft.com/kb/60781/EN-US/) Hardware and Software Third-Party Vendor Contact List, L-P
60782 (http://support.microsoft.com/kb/60782/EN-US/) Hardware and Software Third-Party Vendor Contact List, Q-ZMicrosoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Let me know if u got help and rate me as fixya please!!!
Mar 30, 2008 | Compaq Evo N1000C Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
