Question about Samsung LN-T4665F 46 in. LCD Television
Power light blinking red
Model Number: LC19SB24U, Serial Number: 805908690
No power, Power light just blinks red and nothing else happens?
  • 2 more comments
  • keogheng Dec 10, 2008
    tv in standby mode ,starts up for one second then returns to standby mode and flashes 11 times then stops and begins the cycle again.any hints .
  • hfrank1950 Dec 18, 2008
    Same problem started this evening. Power light blinks red; unit won't turn on with either remote or manual button on side.
  • muteswan Jan 10, 2009
    The screen went black and no matter what I do I cant get a picture. We have working cable and we still have sound.
    The POWER light blinks green but when I push the power button on the TV the red LAMP button blinks continuously.
  • Anonymous Apr 06, 2009
    Monitor worked for about 10 minutes and then just powered down. I was not able to get it started again. Gave it some time and then it powered up. This inconistancy is not good. Any suggestions?
    Problem Solver:
  • 15 Answers
The tv is NOT in standby mode... it does not have a standby mode !!! But what is happening is.. your tv is getting lamp errors. this can be caused by voltage drops and spikes while the tv is on... and a factory reset can correct this. OR it can be one of two problems.. Bad Power supply or defective lcd panel.
Posted on Dec 18, 2008
  • 4 Answers
I had this problem yesterday, when I got home to check it for myself, I realised that there was a problem with one of the input signals (in my case this was a PC cable). The PC I used was on, but had locked up when restarting, therefore the PC was on, but not sending a valid signal to the TV. Everytime I turned on, the red light just blinked.
I realised the TV wasn't broken when I turned it on and managed to change the input source (while the light was blinking) back to HDMI (Sky), then the TV was fine.
When I noticed the problem with the PC, I forced a shutdown and then restarted it properly, and then everything was fine.
To summarise, if you have a red blinking light, its not neccessarily a fault with the TV, but it might be just confused about which signal it should be taking when it goes on.
  1. Try changing the source as soon as you turn it on and when the light is blinking.
  2. Disconnect your input cables and try them 1 at a time, (in various orders)
  3. Turn everything completely and utterly off (In my example above, the PC is a laptop so had its own power supply)
  4. If your TV is still blinking when nothing is connected to it (not even HDMI or SCART) then you probably have a problem.
I'm not a TV expert, but I do like my gadgets and tech stuff ...... and that was how I fixed the problem... I hope this helps anyone who reads it.
Good luck !
Mitch
Posted on Apr 21, 2009
There is a Firmware upgrade go to philips.com and enter in model # of your t.v. download software to a memory stick and insert into usb port on side of t.v. turn on t.v. and the menu will pop up showing you that it is upgrading. Very simple I had the same problem. I just fixed mine. I am actually registering my t.v. now so I can make sure I stay on top of these upgrades.
Posted on Feb 20, 2009
50 PLASMA TV WONT TURN ON RED LIGHT BLINKS BUT NOTHING HAPPENS
By blinking led it show there is some fault. By counting the blinking you can be able to identify which part or board is faulty.
If you wiah to get some more details about flat panel television repair and error codes then check the following link.
http://electro-medical.blogspot.com/
Jul 08, 2016 | Televison & Video
Red light is just flashing on on/ off switch and nothing else will happen
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Apr 07, 2015 | Televison & Video
Can you help?
Check for power supply failure.
Sep 18, 2014 | Hitachi Televison & Video
Two red blinks of the power red light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Philips 32PF7320A 32 in. LCD Television
Red diode blink black screen
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 09, 2013 | Samsung Televison & Video
I turned the Tv off last night and this morning it wont come on it shows to have power the little light on the power button is lit up red and when you try to turn it on it blinks but nothing happens. Model...
almost all of these have bad capacitors in them..
caps
http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
Let me know if I can be of further assistance.
Jul 26, 2010 | Samsung LN32A330 32 in. LCD TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Blinking Red Light - Nothing Works
Call Sony, give them serial number (rear of unit) provide descripton of problem and failure to operate after powering off and they will issue a case number and give you an address in Lubock TX to send the unit. Send the unit, with the case number showing on the shipping label, include a proof of purchase, description of problem, return address. Also if you like me, have CD's in the changer make sure you note that during the telephone call with Sony and again on the description of problem. Very fast phone call.
Oct 20, 2008 | Sony CMT-CPX22 CD Shelf System
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
May 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung LN-T4665F 46 in. LCD Television Logo
4,161 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
