Question about Whirlpool Kitchen Ranges
Carcon monoxcide detecter goes off after oven use
    Habit-Forming:
  • 171 Answers
The oxygen vents need to be open some more, this are located as the burner meets the valve that supplies gas to it.
Posted on Dec 10, 2008
Main oven keeps going off
If you mean the heat keeps turning off??? The heat will turn off when the thermostat detects the desired heat level has been met, after that, when the level of heat goes below the selected level then the oven will heat up again granted if the thermostat is functioning correctly. This is the best answer I can provide for vagueness of the question.
Nov 03, 2013 | Baumatic Ovens
Rev below 500rpm on idle, engine dies
check for dirty fuel filter at engine,,,also you can try one more additive...SEAFOAM...nine bucks a can...add to your gas tank, the trhottle body...follow direstion on the can....don't be alarmed that the engine might smoke...it is temporary and usually fixes fuel problems caused by dirt of carcon build ups....houpe you can use this info
Sep 11, 2012 | 1996 Hyundai Accent
Carbon monoxcide smell when oven running ?
I have to assume your oven is gas-fired but it helps to have make and model info.Carbon monoxide is odor- and colorless; that's why its dangerous. I don't doubt that you have poor combustion and it may well contain the gas in the fumes. Check for yellow flames which are a sure sign of an improper gas-to-air ratio. If you do, you may have a buildup of residue causing the problem.
Dec 27, 2011 | Ovens
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
Have a Belling GT755 and when I press the knob for the oven it ignites, but then when I release the knob the gas/flame goes out. I am having to keep the knob pressed in with a mop head or adjustable...
The oven has a flame detection installed that makes sure the gas turns off if the flame goes out. There are two component that do this. One is the flame detector and the other is the control device that turns the gas off,. Either one of these cold be faulty. The cheapest way is probably to replace the detector in the oven and if that does not work, replace the gas control device.
Jan 03, 2018 | Belling Solitaire G755 Gas Kitchen Range
On my countrychef 100g gas range oven lights but when control knob is released it goes out
The heat sensor that detects the flame is not working properly. Consult a qualified Gas Engineer as this is a safety critical item.
Dec 26, 2010 | Belling Microwave Ovens
After oven turn on and heat up and reach temperature short thereafter unit goes into F1
F1 means the system watchdog cicuit has detected a fault.
Try pressing CANCEL for 30 seconds if it continues after that you will probably need a replacement control board.
Dec 13, 2010 | Dacor Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
First alert smoke and carbon monoxcide beeps periodically.
You need to give the exact model I bet you have a battery back up in the event power is lost during a fire. I bet the battery is bad.. We all have had devices that are brand new and the shipped batteries are no good.
Please rate my service  PJ
Dec 03, 2008 | First Alert SA302 Dual System Smoke...
Kitchen Ranges Logo
37 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
