There is a sensor that need to be cleaned if the code will not clear. I believe there is a black float that is part of the fuser bottle. If you swing out the oil bottle and look where the float would be... There is a sensor, clean the sensor and make sure it is plugged in correctly... Good Luck
Should be located behind the fuser oil container. Open the front door. Lower left corner. Swing out the oil bottle. Should be right there. It just slides out.
I don't believe this machine uses Fuser oil. I bet it was picked up from a sight that had other machines and the oil was just put inside the machine as it was being wheeled away.
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Would you like a little insight? I would take Bubbabear64 suggestion. If the oil bottle is not full, the disk it the bottle will un block the sensor that is telling the copier that it is all out of fixing oil, FYI the cost of the oil is about $70.00, so your price is most likly $150 - 250 maybe. To reset the code you have to go into service mode.
at the time of creating stock item in inventory information menu, you press F12 confi. and set the option "Allow standard Rates for stock items" and accept the configuration screen then set yes to the stock item creation screen. this screen contain the standard price(purchase price) and set the selling price.and accept all the screen.
thank you
