Question about Samsung CLP 300 Laser Printer
Hi, This is a problem which was on/off for some time: when start printing the paper is not going inside to be printed.In last couple days I was able to "assist it" pushing it slightly and it was OK. Today it will not load and keep showing red light
  • shawnjf Dec 11, 2008
    I have found the CLP-300 paper pick up problems to be one of poor design. I completely pulled my printer apart and reassmbled it, checking every single part. It still refused to pick up the paper and print. In attempting to diagnose I laid the printer on its left side and sent a print job, so I could watch the underside, finally it started to print correctly. I printed 10 pages straight without failure on its side. The paper pick up mechenism is very finicky and samsung should be ashamed of this product.
    Problem Solver:
  • 5 Answers
I had same problem. It got resolved by lifting the front part of the tray a little forcefully. I put a spare USB drive under front part and now it works fine.
Posted on Dec 25, 2008
  • 53 Answers
Check to make sure your rollers are placed in correctly and make sure its picking up properly.
If your unsure where these are then look to your manual for assistance, if you have misplaced this then to go the manufacturers website and download a copy.
Hope this helps.
Posted on Dec 10, 2008
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
Epson RX580 has been printing fine after installing complete set of authorized genuine Epson cartridges last week. I printed 12 DVDs and switched over to printing on paper and it worked fine for a couple...
Hi there, I would simply pull the ink cartridges out completely and then put them back in. It should act as if you are putting in new cartridges and go through the install process again. I hope this works for you!
Jan 15, 2011 | Office Equipment & Supplies
I printed a report from the internet a couple of days ago. Now my printer continually prints header information (one line) over and over. It won't stop! If I load the paper tray, it immediately starts...
Take the paper out, go to control panel - printers, open your printer's folder, and choose from the menu Purge all print jobs. If you have some kind of printer status monitor, go there and look for any job that's pending, and try to cancel it. Now turn the printer off, on again, and insert paper - it should be over.
Nov 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Ink has run out message
Ink not made for your printer has risks. 20 years as Canon rep taught me this. Yields: are affected by resolution, type of paper, condition of print head, condition of ink jets, all ink jets and lasers are mfg'd under lisence to Canon. You have the best! Anytime supplies are cheaper, something is left out. used cartridges usualy leak air and drip ink ck for stains under print head. cartridge has used blotter also drips. Cheaper cartridges contain less ink, no free lunch. Fill it yourself 1 or 2 times and do it right. Put the printer in your shower for twenty minutes if you see excess leaked ink. Allow to air dry for a few days then install new cartridges. Run all the Nozzle checks and print head utilities. Touch nothing else on the inside. This will fix it or f@#%k it up for good
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
LEXMARK 1240
need to install printer to my lap
Sep 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
