Question about Galaxy Radios DX-33HML 40-Channels Base CB Radio
Connex 4600 turbo
I received a this radio recently and ran it hot in a box with no muffin fans on the heat sink. intellegent. the radio turns on and is able to receive still. the needle moves in receive mode but not in transmit. did i burn out the duel 2sc2290's or could it be something like a drive or worse??????
    New Friend:
  • 83 Answers
Yup you fried the finals
Posted on May 31, 2007
2 Suggested Answers
  • 125 Answers
SOURCE: connex 4600 turbo
It is lkikely that you burn the output transistors. You can easily check these transistors even if it is soldered but be aware of low resistance paths like coil , toroid, and lo ohm resistor which might affect the reading in the multitester. To be sure desolder at least 2 pins before testing. I do not think that the driver is damaged.
Posted on May 22, 2007
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I would say yes it has a large heatsink. The variable might be the tuning. But if it's amp is not being pushed any harder than factory you will be fine. Nice radio I prefer them over the 4400turbo and the 3600hp it has the board like a 4300 not the 3300s like the fore mentioned.
May 26, 2014 | Connex 4600 Base CB Radio
Connex 4600 turbo radio stays keyed up even with mic disconected
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Mar 28, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo. Poor receive. About 4 mi.
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
May 20, 2009 | Connex 4600 Base CB Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Feb 10, 2009 | Connex 4600 Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Connex 4600 turbo
Mar 01, 2007 | Galaxy Radios DX-33HML 40-Channels Base CB...
Galaxy Radios DX-33HML 40-Channels Base CB Radio Logo
250 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
