Question about NetGear WGR614 Wireless Router
Netgear No Internet connected detected
I have been trying to install my netgear wireless router wrg614.
I reached the ACTIVATE THE NETWORK part.
My laptop would indicate on the system tray that i was connected. Earlier it told me that I have a PPoE connection.
I could not get the password to work
Now, it is worse because it could not even detect that I am connected to the internet.
i followed everything but I still could not make it to work. Please help me. I am about to throw this brand new NETGEAR into the trash can.
I CAN NOT CONNECT TO INTERNET THROUGH WIRELESS AS I AM UNABLE TO COMPLETE THE INSTALLATION ON MY DELL VESTRO LAPTOP.
    Scholar:
  • 86 Answers
Are you sure you have a PPPoE Modem? Usually these are DSL connections from Phone and Satellite ISP's... But there are also other ISP's that use them, although a very large percentage of ISP's just use DHCP. Try to set the router up using DHCP instead of PPPoE and see if that works...
To check if you are on the internet:
Start-> Run -> cmd [enter]
in the black box:
ping google.com [enter]
another useful command is:
ipconfig
Posted on Dec 11, 2008
Need the download for wrg614 wireless router
You do not need an installation download to setup the Netgear Wireless router.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 25, 2012 | NetGear WGR614 Wireless Router
Just installed Netgear511B. It shows I'm connected
i would go into internet options in explorer and go to connections, then lan settings.verify that auto detect settings is checked, then click ok. restart pc and try ie.
Apr 30, 2010 | NetGear RangeMax NEXT WN511B...
Cannot conect my Router
1.Did you set an IP address to the new router? If no.
set it to 192.168.1.2 or in DHCP mode.
2. Install the new AP software(i.e uninstall the older version from your PC/laptop) which would be available in CD for the new router package.
This will solve the problem.
Oct 19, 2009 | NetGear WGR614 Wireless Router
Cannot connect to my Netgear WRG614 v6 Router. My Dell laptop shows an excellent connection but it says limited or no conectivity? I have tried several suggestions and reseting several times...nothing...
If you are using LAN cable from your ISP. Try to connect it to your Computer LAN port directly or how you connect directly your internet connection from your computer without the router. Then on your system tray try to look the internet icon activity usually a two monitor icon. Right click on there. Then select status,then support, then details, from there see the DNS number you may get two DNS numbers set then put that manually to your wireless lan settings.
Jun 06, 2009 | Computers & Internet
Cannot connect to my Netgear WRG614 v6 router. My Dell laptop shows an excellent connection but it says limited or no conectivity???
if it says limited or no connectivity, it means that there are a couple of settings that needs to be configured for your wireless connection. click on start > run> connections> wireless connection >when you see your wireless network, try to disconnect from the network and try to connect again using the right wep key (if you have it enabled). or you can try checking the wireless properties. start > run> type in ncpa.cpl and hit enter. right click on wireless connection and click on properties. highlight tcp/ip and click on properties. make sure that the settings are set to obtain automatic. hope this one helps.
Jun 04, 2009 | NetGear WGR614 Router
Problem connecting wireless to a Netgear MR314
Login to router and change the wireless channel on which the router is transmitting wireles signals.
Pretty old router that you have. Ugrade your router and stay tension free with the newer routers as they work fine and have low downtime.
May 16, 2009 | NetGear MR314 (MR314NA) Wireless Router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a DSL connection that does not require a login, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection that requires a login, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Nov 17, 2008 | NetGear WGR614 Wireless Router
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Router does NOt connect
why not you can connect the internet. first you tell me how much mbps now you using ?
Jun 12, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
102 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
