Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Unsure how to login to planet router
I am unsure how to login to planet router .i dont have mac address this is a second computer another user is already logged in and i need this as a second computer
    President:
  • 623 Answers
To find a user manual go here.
The default login for your router you can find here.
The default address is 192.168.1.1, but you did not mention which router model you have. So go to the first link and download the manual for your specific router. All information should be in there.
Posted on Jan 14, 2009
How to disable MAC filtering
MAC (Multimedia Access Control) addresses are unique sets of codes assigned to electronic devices that identify the devices on a network. MAC filters work by either allowing or denying only specific MAC addresses. MAC filters are a great security measure; however, if your network needs to be open to public or guests, or you're adding and removing devices often, then you should consider turning off MAC filtering.
EditMethod One of Three:
Wireless Routers (Windows)
  1. 1 Open the Command Prompt. You can access it from the Start menu, or by pressing ? Win+R and typing cmd.
  2. 2 Type .ipconfig and press? Enter.
  3. 3 Find your active network connection.There may be several connections listed in the readout, and you may have to scroll up to find your active connection.
  4. 4 Look for the .Default Gatewayentry. This is the address for your router. Write it down.
  5. 5 Open a web browser. You can access your router's configuration page from any web browser as long as your computer is connected to the network.
  6. 6 Enter the .Default Gateway address into the browser's address bar.
  7. 7 Log in with your admin account.Routers are protected with an admin login and password. Check your router's documentation or look up the model online to find the default login information.
    • If you can't figure out how to log in to your router, you can reset it by pressing and holding the Reset button on the back for about 30 seconds. After the router restarts, you will be able to log in with the default admin information.
    • Most default logins use "admin" as the username, and then "admin", "password", or a blank field as the password.
  8. 8 Open the "Advanced" section and look for "MAC Filtering", "Access Control", or something similar. Actually defining where the "MAC Filtering" section is located is very difficult, as the location and labeling is different for every router. Generally, you can find the "MAC Filtering" or "Access Control" settings in the "Advanced" section, though it may also be found in the "Security" or "Wireless Settings" sections.
    • Not all routers use MAC address filtering. Some router's limit access based on static IP addresses assigned to each device.
  9. 9 Disable MAC filtering. Again, the wording and location will vary depending on the router, but you will generally be able to select a "Disable" option to turn off MAC filtering.
    • This may be a checkbox, a button or a selection that you can make.
  10. 10 Save your changes. Click the "Apply" or "Save" button to save your changes to the router settings. Your router will apply the changes, which may take a few moments.
    • If you are configuring your router over a wireless connection, you may be logged out when settings changes are saved.
Jun 08, 2014 | Belkin F5D7234-4 Router
How do I display my routers mac address
Usually, there are two ways to get the MAC address of your router. The first is pretty easy - look for it on a label attached to your device, probably on the bottom. The second is to find it while logged into the administrative interface.
To get to the administrative interface, you must login to your router. Many routers use a standard login name of 'admin' and a blank password, or a password of 'admin'. Your router's documentation will tell your for sure, or just 'Google' your router's make and model and you will typically find the information readily available online.
Once you login, look for an option called 'Status', it may be displayed there. If not, go to the WAN setup area, and you should see an option that is something like 'CLONE MY MAC ADDRESS'. This is usually done to allow you router to 'look like' it's the same as your PC. You would do this if you originally had only a single PC hooked up to the internet and now you want to add a router. So, you probably don't actually need to perform this operation, BUT.... going to that screen will almost always display your router's MAC address.
If all else fails, you can ARP to or possibly just PING/full the router to get what you need, but that's way to complicated, and you shouldn't need to do that.
Start by turning it over and looking at the label....
Sep 19, 2013 | Yard Machines 155 Torque Briggs Stratton...
How can i block my router TM-G5240 to other computers?? tks
one word "permissions"
you have to tell the router and the firewall that you don't want "abc" user to use the router.
this is done by logging into the router and allow/disallowing the user by MAC address ( Media Access Control) .
depending on the router to access it is going to a browser window and entering either 192.168.0.1 or
192.168.1.1
instruction set to secure your router is in the "helps" file.for
1.select the "Advance tab
2. select filter "MAC'
3. Enter name
4. under MAC address enter MAC address
5.on the DHCP Client select DHCP client from the pull down list; click Clone to copy that MAC address
Jul 23, 2011 | D-Link Tmobile Hotspot Tmg5240 Wireless...
Help configuring my router
Hi Friend,
Please follow the steps in order to resolve the issue:
Make sure you have connected each and every wire/cables to their respective ports/places.
1. Open web browser and type the IP address of the TW100-S4W1CA in the address bar. The default IP address is 192.168.1.1. At the LOGIN, click LOGIN and click on Advanced Setup.
2.Click on WAN and then click Dynamic IP on the left hand side, then select Dynamic IP (Cable Modem) and click on Apply.
3.If your ISP has registered the MAC Address of your computer that you are managing the router from click on Clone MAC Address. This will copy your computers MAC Address to the Router. If you are not managing the computer from the computer with the registered MAC Address make sure you enter the registered MAC Address manually.
4.Click on Apply.
After saving the settings you have to power cycle the modem and router(Turn off the modem and router for 15-30 seconds).
* Reconnect the modem first and wait for it to boot up.
* After the modem has booted up reconnect the Router. Open the web browser and type the IP address of the TW100-S4W1CA in the address bar. The default IP address is 192.168.1.1. At the LOGIN, click LOGIN, then click on Advanced Setup.
* Go to System then Status on the left hand side of the screen
* If there is no WAN IP listed in the WAN section on the right hand side of the screen, click Renew and wait for it to come back with an IP address
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 07, 2010 | Trendware TRENDnet TW100 S4W1CA...
About a year ago a friend set up our wireless router the problem is they didnt know they were doing it and now we dont know the Password to log in on other wireless machines laptops etc i simply need to...
Log in to your router's configuration page using your internet browser by typing "http://192.168.1.1" in the address bar.
Type in “admin” for both username and password which is the default user name and password.
Click on “Setup” at the top
Scroll down to “Network Setup”
If you have forgotten the router's user name and password, and the default user name and password aren't working, try resetting the router back to factory defaults:
With the router powered on, hold the reset button (located on the back of the router) for 25 seconds. Then disconnect the power from the router and wait 10 seconds before plugging it back in.
After the reset, you should be able to login to the router with the default user name and password.
Jul 24, 2010 | Airlink AR430W Wireless Router
Where would I find the wireless key for my d-link router
You need to login and set it via the admin control panel. You need to know the IP address of the router first. Usually it is, http://192.168.0.1. If you are unsure, go to a computer that is connected to the same network and check out the default gateway. You can do this by going into the command prompt when using windows and by using the terminal on a mac.
Unless the password for the admin panel is not set, you can use the default pass which is admin. Or you can try password or passw0rd. After logging in, you should be able to see the Wireless settings, and finally the security settings for it.
Jun 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
I want to log in to my routers ip address
Connect your router to computer with ethernet lan cable.
Then you can access with below link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If you are unable to login with above ip then you need to reset router.
For that press RESET button for 10 seconds it is in back side of router.Hold it for 10 seconds thenj all settings defaults.
Then try with above ip .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | NetGear WGR614 Wireless Router
I am starting to install Netgear RangeMax Wireless Router WPN824 v2 I reset to factory settings. I have windows XP professional. The unit is powered, and connected to the internet. what is the next step?...
Once you have your router connected to your Modem, connect your computer to any open port on the router, and with your Web Browser, go to http://192.168.1.1 and log in to the router. Login is (default) login name is admin and default password is just a blank field. Once you have logged in to your router, go through setting up things like IP address (leave at "Get Dynamically from ISP". Same with DNS server --- "Get automatically from ISP". MAC address should be already filled in. Click Apply. You should be good to go for wired router use, and if you want to use it wirelessly then you need to click "Wireless Settings", pick your SSID (Name of your network) and any security you choose. After this you ought to be set for wireless access as well.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Ineed to access the router to lock it
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.1.1)
3. Enter the router setup, login and password (default Login = admin
and default PW = admin unless you have already changes it)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | Linksys Wireless-G WRT54G Router
Belkin F5D8233-4 router & I pod touch wifi
What I would try is while the wifi is unsecure go on the computer and open up the browser you are using, on your router the default ip address is 192.168.2.1moz-screenshot.jpg
type the router default ip address in the browser where you would normally type a web address www.google.com
Logging into the Router
You will see the Router’s home page in your browser window. The home page is visible to any user who wants to see it. To make any changes to the Router’s settings, you have to log in. Clicking the
“Login” button or clicking on any one of the links on the home page will take you to the login screen. The Router ships with no password entered. In the login screen, leave the password blank and click the
“Submit” button to log in.
Configuring the Wireless Network Settings
The “Wireless” tab lets you make changes to the wireless network settings. From this tab you can make changes to the wireless network name or Service Set Identifier (SSID), operating channel, encryption security settings, and configure the Router to be used as an access point.
Setting up an Allow Access List
1. Select the “Allow” radio button (1) to begin setting up a list of
computers allowed to connect to the wireless network.
2. Next, in the “MAC Address” field that is blank (3), type in the
MAC address of the wireless computer you want to be able to
access the wireless network, then click “<<Add” (4).
3. Continue to do this until all of the computers you want to add
have been entered.
4. Click “Apply Changes” (5) to finish.
this will allow only the wireless device you select to access your router.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
