Question about Servis 23 in. M4306 Free-standing Dishwasher
Servis easi logic dishwasher not draining, now stuck!
Seems to have stopped before rise cycle, not drained after wash. Now control panel locked.
5 Suggested Answers
  • 1462 Answers
SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Posted on Mar 20, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Drain pump goes ON when ON-OFF button is pressed, even if the know selector is in OFF position and the machine is dry. There is no fault codes and the dishwasher complete the washing cycle OK, but when...
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
Aug 08, 2011 | Miele G7856 24 in Dishwasher
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher does not drain...stops in cycle...no matter what cycle
HI, this is a control fault. the logic chips are malfunctioning. these chips are responsible for initiating the proper washing cycle sequences. you will need to replace this damaged control board asap.
Click here to order your new control board online.
Jun 04, 2009 | Maytag MDBH955AWS Stainless Steel 24 in....
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Servis 23 in. M4306 Free-standing Dishwasher Logo
324 people viewed this question
Top Servis Dishwashers Experts
Are you a Servis Dishwasher Expert? Answer questions, earn points and help others
