Question about JVC AL A158BK Turntable
JVC- Turntable not working
Model DR-E31BK/DR - E31LBK
  • malcolm_qual Apr 07, 2009
    JVC - problem. The turntable does not move, normally when a record is put on turntable and the stylus moved across the record the tt automatically starts moving but nothing triggers this happening.
  • David Dunn
    David Dunn May 11, 2010
    What specifically does it do and what does it not do?
2 Suggested Answers
SOURCE: I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
http://www.retrevo.com/samples/JVC-DVD-Players-manuals.html
Posted on Jul 07, 2009
Grubhead
  • 4678 Answers
SOURCE: I have a JVC AL
Normally these low power turntables connect to a unit audio system that supplies them with power. If you find out that you should be able to track down the specifications of it.
Posted on Jan 09, 2011
I have a jvc turntable QL-F320 and the power does not come on. Is there a fuse or something easily replaceable for this?
There will be yes! But if it is as simple as replacing it, I would doubt.
There's a service manual for the model on e-bay at the moment!
If you get stuck.
http://www.ebay.co.uk/itm/JVC-QL-F320-QL-F320B-turntable-service-manual-original-/131584946151
Mar 22, 2016 | JVC Audio Players & Recorders
Putting on rubberband on turntable jvc
Hi check the video to find how to insert the belt on a turntable.
AJIN
Aug 15, 2012 | JVC Audio Players & Recorders
I have a JVC AL E31BK turntable that I want to connect up to my system. I need a power adaptor for it. It says it requires 11-13volts but I don't know the amperage required. I don't want to use the wrong...
Jan 08, 2011 | Audio Players & Recorders
I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been to feint of heart to do it, but it worked great.
Oct 25, 2009 | JVC AL A158BK Turntable
JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Jun 20, 2009 | JVC Audio Players & Recorders
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Feb 10, 2009 | JVC AL A158BK Turntable
JVC AL A158BK Turntable Logo
133 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
