Question about Elna 2007 Mechanical Sewing Machine
Elna Contessa710 Machine sews straight on dial "0". When I change to 1 - 5 it should zigzag, but nothing happens. Dial does not "feel" broken, but could it be? I have cleaned it, oiled it, and rested it....
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
SewTechWayne
  • 186 Answers
SOURCE: zig zag won't work
Make sure stitch width slider is not set to zero. If not then you either have a bind in the needle bar pivot or an electrical problem (bad stepper motor or bad circuit board).
I can't remember if this machine has a twin needle lock out, if so turn it off.
Good Luck!
Posted on Feb 01, 2009
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
  • 1116 Answers
SOURCE: My Elna 6005 Heirloom
When you switch sewing modes, what does the display read as far as the stitch type you are using?
Posted on Aug 19, 2011
Tally Girl
  • 1133 Answers
SOURCE: How do I turn the selection dial to zigzag on my
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
Posted on Nov 07, 2011
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
Jan 25, 2014 | White Sewing 1418 Mechanical Sewing...
How does one get the kenmore 12102 to sew in zigzag stitches?
The dial at the top right hand of machine ,turn it fron 0 to 1-5 for zigzag
May 20, 2010 | Kenmore 12102
Hello I have an old Riccar 6800 sewing machine
Hiya, the threading for this machine is pretty standard so you won't be going wrong there. Have you used a sewing machine before? The tension dial (on the extreme left) should be set at 5. The other dial to your left should be on blue zigzag with orange broken line. The dial on the right should be set at 0 and the bottom one on 2 - 3. I've been looking for a manual for this machine as I inherited this one. It took me ages to suss straight sewing out. Another thought is take it to a repairer and ask for a quote. Good luck.
Nov 20, 2009 | Riccar Sewing Machines
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
PFAFF 362 Sewing Machine: The shift lever to move from straight stitch to zigzag stitch is stuck in zigzag mode and will not release to go back into the straight stitch. The machine sat unused for a...
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Sep 25, 2008 | Singer 7462 Mechanical Sewing Machine
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Elna 2007 Mechanical Sewing Machine Logo
32 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
