Question about SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader
Write protected flash driver
When downloading songs to my sd card,it says the disk is write protected
  • 298 Answers
Tiny switch located in a slot on the side or top. Just slide it the other way ;-)
or
Your computer is scanning it for virus and LOCKED it temporarily.
Posted on Jan 17, 2009
Removing write-protection from SD card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2012 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
My sandisk is failing to format even to delete items which are inside it is saying disk is right protected whilst it is not protected
Hello Sean,
Please try to format the SD card using the SD Formatter 3.0 for SD/SDHC/SDXC. The software formats all SD memory cards, SDHC memory cards.
Download the software from the link provided below :
http://www.sdcard.org/consumers/formatter_3/
Jun 20, 2011 | SanDisk 4GB microSD High Capacity Memory...
8gb micro SD card cant be formatted
if your SD Card is not write protected and you wont able to format it a virus may have mess with your memory card. Format it in safe mode or you can try a formatting utility that you can use. You can download it on the link below:
http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 27, 2011 | SanDisk 2GB microSD Memory Card
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Disk wright protection
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 17, 2010 | SanDisk 2GB microSD Memory Card
My pny 2gb micro sd memory card is write-protected, i couldn't store or delete any files. what should i do? pls help me.
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
Jul 05, 2010 | PNY 2GB microSD Memory Card
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Write protected
micro sd card have a little switch on the side, move the switch to its other position to enable disk-writing
Jan 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant take songs off Says " Write Protection"
There is a LOCK switch on the side of the SD Card.
Slide it away from the LOCK and youll be all set.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader Logo
137 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
