Question about Lexmark Wheelwriter 1000 Typewriter
Space bar does not work - any suggestions what is wrong?
  • rosemarie_he Dec 15, 2008
    Thanks for the info - space does not work - can not move it at all.
    Thanks
  • 328 Answers
Have you spilled anything on the keyboard? Raise the unit up on its back and see if there are any little pieces of round plastic bits missing from the keyboard. If so, then the keysheet insidr is not makong contact and will need to be repaired. That is a $75 to 100 dollar repair.
Posted on Jan 12, 2009
    President:
  • Lexmark Master
  • 3,594 Answers
Assuming this is a WW1000 the space bar will come off with a nlittle prying pressure under the center of the bar. Remove it and check for debris under it.
DickyO
Posted on Jan 08, 2009
  • 549 Answers
You may have some linkage that came disconnected or an obstruction under the spacebar.
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Try this, because you may have tabs set and it is not allowing you to move the carriage with the spacebar.
If this does not help, let me know. Thanks.
Posted on Dec 10, 2008
2 Suggested Answers
  • 3594 Answers
SOURCE: space bar does not work??
If the space bar won't go down there may be some debris under it,
DickyO
Posted on Jan 02, 2009
Why doesn't anyone answer my question.. Have a Xerox 620C Memory writer. space bar doesn't leave a space between words
Most people only answer questions under 2 circumstances:
1) They have to see the question. Since there are a LOT of questions (Like thousands every day) we volunteer FIXYA helpers only see a few of them. Then,
2) We have to think that we either know the answer, or might be able to help you find the answer.
Then we reply.
My guess or suggestion regarding your problem, and I assure you that I don't know the answer.......
- Possible defect with your space bar
Would it be possible to have it checked by a technician?
Hope this helps.
Cheers
Jan 31, 2016 | Office Equipment & Supplies
When I hit the spacebar it jumps 2 spaces
Look closely at the space bar. try to lift it on the right side and on the left. The bar may have popped out of place. Specifically a metal rod that holds the space bar in place. Or the space bar is not resetting fast enough, ( soda, honey, something sticky) causing the bar to reset slowly.
Nov 01, 2013 | Lexmark Wheelwriter 10 Series II...
Beep when hitting space
You may have spell check on. goto nadist.com the nAE740 is the same as your T/W you can download the manual.
DickyO
May 23, 2013 | Swintec 7040 Typewriter
The space bar won't work
look for debris under the space bar, if not proubably needs keyboard disassambled and cleaned.
DickyO
Oct 11, 2012 | Brother SX-4000 Electronic Typewrite - 10...
My lexmark typewriter space bar will not work and the phrase light is stuck on
The phrase light is also the single space. If only the space bar doesn't workyou may have a bad keyboard or something under the space bar that is in the way.
DickyO
Aug 23, 2011 | Lexmark Wheelwriter 1500 Typewriter
Have an old Brother Deluxe 650TR portable that hasn't been used for a long time. The carriage will move but will not stay at the right margin after being returned. Any suggestions?
Does the carriage just move back and forth on its own? Space bar work? The escapement may be sticky from lack of use. You may be able to see it from the upper rear or the bottom. It will move when you hit space bar or keys. Try working WD40 into it, it'll take a bit of use to free.
Nov 27, 2010 | Brother Office Equipment & Supplies
Galaxie twelve power-space bar
There is an adjustment for the power space bar..looks like it is pulling the escapement out too far. Not something for a novice to try..It may also have a bind in it.If so just try to wiggle it to remove the bind.
Hope this helps
Squipps
Jul 21, 2009 | Smith Corona Office Equipment & Supplies
Space bar does not work??
DickyO
Dec 10, 2008 | Lexmark Wheelwriter 1000 Typewriter
Space bar
If the bar works when you hit right in the middle try reinstalling the bar the metal rod must go under the tabs on the keyboard, if it won't at all you probably need a keyboard.
DickyO
Jun 02, 2008 | IBM 3500 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
241 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
