Question about Philips HTS3450 System
HTS3450 - Replaced Capacitors now have sound back but is very low
So I correctly replaced the two faulty 470uF/16v (note on my system they were 16v not 25v) with blue 470uF/35v capacitors I bought from radioshack. There is no more buzzing but just like before i replaced them, there is hardly any sound coming out of the speakers even at max volume. The sound is clear, and even the subwoofer is a kicking a bit, but I can barely hear it without turning everything else in the room off. I even swapped out the amplifier board with a new one and I still have the same problem so I'm thinking there is still something wrong with the power board.
Can anyone help?
  • anon291842 Dec 10, 2008
    I replaced the power board with another, and changed out the capacitors on that one also. It is now working non-stop without any problems whatsoever.
    I will reply to this again if i can fix the other power board. I think I just blew the **** out of it.
  • jutterback May 11, 2010
    are the caps electrolytic or ceramic? do i replace C905 &C906 or is it caps C913 &C914? I can do the work but Wheats thread left me confused with the cap specked at Radio shack. should I use 16V or the 20V for the loss of sound? Thanks for any help!
    Scholar:
  • 144 Answers
The new capacitors have a lot more value than the factory ones. Because of the higher value the amplifier will have to give it all it's got and mostlikely not live for too long (see first comment).
Replace the replaced capacitors with ones of the correct value and your problem is solved. You can use ones with a slightly higher vlaue (20v iso 16v) but it will also produce less louder sound.
Posted on Jan 29, 2009
I have a philips HTS3450/37 replaced the caps got ride of the buzzing but still don't have sound on sub center channel or left front any ideas
Hi Gerhodes. The answer above is correct with one exception. The reason this has been found to be such a problem with the Phillips HTS 3450/37 model is due to the fact that parts positions numbered "C987" and "C989" are not powerful enough . If you take the "Black backplate" off (the one that the otherside actually shows outside when asembled. Right about where the plate was removed between the "Metal Wall" as it resembles and the "Main Power Conductors" which are covered by the metal top plate and wrapped in yellow or some other color tape. So, as you see that area, at the back are 4 capacitors. Two are small and neither of those two are the same size as each other or the other two in that area. There are two capacitors of those 4 that are set in a diagonal position from each other, They are the same size as each other. Those are the ones that you want to replace. They 470uF/25v. What creates the issue is that these capacitors are not large enough to handle the power needed. So, when you replace it you want the equivalent of a 470uF/35v to supply enough power. Once you replace the weaker ones with the more powerful capacitors ensuring to solder on the opposite side of plate (green side), you should be good to go.
Good Luck,
cJager
Jan 11, 2012 | Philips HTS3450 System
Philips HTS3455/98 System "NO SOUND" PlZ Help!!
There are two capacitors on the power board that are 470uf/35v. go to Radioshack and buy two catalog #272-1030 470uf/35v radial lead capacitors. if you have soldering wick and a soldering iron, then this will cost you under $3.00. when you remove them, the capacitors have a white strip with a negative sign on it. match this up with the shaded area on the board. put it back together, and it will work, and last a long time. I have this same system, and it wouldn't play any sound. so, I replaced the capacitors. Hope this helps!0ccab8c.jpg
Nov 30, 2008 | Philips HTS3450 System
Hts3450 Sound Gone
Here is a picture of the Power Supply PCB. The location of the 470uF 25v capacitors is marked by the red circles. To locate these the two circuit boards need to be separated. Pictured are the replacement 35v capacitors. Thank you to WheatService for discovering the solution. I hope this helps. I went to Radio Shack and got them to do the soldering for me. It cost a total of like $15. The sound works like normal now.
Oct 13, 2008 | Philips HTS3450 System
Capacitors - Philips HTS3450 System Problem
Are you sure you are looking at the right board? I was looking at the wrong board (the one with the long, low heat sink and lots of capacitors). I can post or e-mail you a picture of the location if that will help.
Aug 13, 2008 | Philips HTS3450 System
No Sound
you are probably actually looking for two 16v capacitors, not 25v. They are either black or brown near the huge copper coil magnet capacitor at the end of the board. A thin, tall metal heatsink sits between it and the copper coil capacitor. Philips is notorious for their completely worthless stereo systems, so they probably knew about the problem with the capacitors and put in 25v for later versions of the hts3450.
Phillisp HTS3450
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 06, 2008 | Philips HTS3450 System
Philips HTS3450 sound problem
Jun 09, 2008 | Philips HTS3450 System
No SOund from the HTS3450
Apr 20, 2008 | Philips HTS3450 System
Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
Apr 06, 2008 | Philips HTS3450 System
Mine buzz for about a month and now it is turning red light and no sound..... anything I can replace to fix it?
Dec 18, 2007 | Philips HTS3450 System
Philips HTS3450 System Logo
469 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
