Question about Ricoh Aficio 450 Copier
Looking for a part for Aficio 450 copier. It was referred to as the controller for the lamp, but we don't know the name of the part....
  • 1 more comment
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    The part could be called the lamp regulator. What is the error code you get?
  • Tim Babcock
    Tim Babcock May 11, 2010
    I took a picture of the part I think you are looking for. If you give me your e-mail address, I'll send you a copy of it to see if that is the one you are looking for.
  • Tim Babcock
    Do you have diagram or a picture of the part you need?
    I have one here that we can sell you. Contact me at tbabcock@northpacificofficesystems.com for additional information.
  • 183 Answers
The part you need is called Lamp stabilizer and the part number is:
" AZ500052 "
Posted on Jul 11, 2009
Ricoh aficio 4850 emf
Most fuser problems have to do with the fuser lamp and or the thermistor, or the thermal fuse. If you can put you hand near, and I did say near, because the fuser is very hot and can burn you, you should feel heat. Use an inferred thermometer to pick up heat. Should be around 225 degrees F +- a few degrees. If no heat detected the lamp is bad or is not receiving voltage. The thermistor detects heat from the fuser roller, it lays on it, and sends a signal to the logic to turn up the voltage to the lamp or turn it down. The thermal fuse could be open hence not voltage to the lamp. Last but not least no power from power supply or no signal from logic board to turn up the juice. Hope that helps.
May 11, 2014 | Ricoh Aficio 450 Copier
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
My copier is ricoh aficio 650 during it self test and worming time the message appear sc101 - 00
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
May 13, 2011 | Ricoh Aficio 450 Copier
I need to reset the terminal name and number on the fax portion of the Ricoh Aficio 450 copier. Can anyone assist what that?
The fax user manual for the 450 is no longer available from Ricoh, so I can't check for sure, but the basic procedure is to press the User Tools button, go into Fax Features, and under one of the tabs will be a box where you can change the fax header information.
Hope that helps!
May 25, 2010 | Ricoh Aficio 450 Copier
What is the defrance between aficho 450 & 2045
the aficio 2045 is new version of the aficio 450.
so on the 2045 if you have installed printer/scanner option you can scan directly to folder on your computer or you can scan and sent documents to email addresses ,also the print or copy is much more quality.
you have a touch screen control panel.
mainly the look is the same with some new design on the look, but also some staff which has bean detected as problem on the aficio 350 now are corrected and improved.
Dec 13, 2009 | Ricoh Aficio 450 Copier
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
Error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Mar 28, 2009 | Ricoh Aficio 450 Copier
Nagah ( aficio 450 )
Are you talking the control panel?
Jun 17, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
131 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
