Question about Dell Inspiron 1501 Notebook
How do u put a enter button bk on
I was cleanin my lap top and my bangle pulled the enter button off and all the clips and the little plastic things have come off 2 and i dont no where they go can u help me plz
  • 117 Answers
If you dont know where connectors lost then only solution is to go PC store where they sell or fix dell laptops.
Posted on Dec 10, 2008
  • 38 Answers
If the plasic clips are damaged then you can get replacements from ebay very cheaply, just search for you laptops model number + replacement keys, most will come with the clips and instructions on how to fit them.
If they are intact then they will just clip back onto the keyboard, if you tell me the laptop model i can tell you how, there should also be a little rubber "spring" which allows the key to spring back up. for most keyboards they will go back on with the wider edge at the bottom.
Disk stuck in Samsung laptop .need to find release button for top of lap top
there is a small hole on the drive put a paper clip end in the hole and push in on it it will come out a some than pull it out ok
Oct 30, 2013 | Computers & Internet
Is the wiring going to multi function switch part of main harness or can I change it somehow.
Part of the main harness. Once the wires leave the multi-function's harness connector, the wires go everywhere.
So the wires are pulling out backward out of the plastic connector? There is a feature on the wire terminals to keep them in place on a connector and not let them slip back out. A tiny little metal clip on top of the wire terminal is raised just enough that when the terminal is inserted into the plastic plug, the clip will ride over a bump in the plastic, then be raised enough that when pulling on the wire from the back, the clip will prevent wire from being pulled out. Look at the loose wires and find that little metal clip (on the top of the terminal pin), bend it up and try re-inserting the wire into the plastic connector. When it slides in and locks in place, and will not come back out, you have done it right.. I hope I understood you right, and this is helpful. Good luck.
Dec 03, 2012 | Cars & Trucks
How to open Sony remote RM-GD005
1 - Remove the battery cover and undo the two screws.
2 - On the front of the remote down the bottom there is a slider that covers some additional buttons. Slide that down then twist/lift/pull until it comes over. Be gentle.
3- Looking from the top, along each side, between the black front and the silver side pieces, push a small screwdriver in the join to open it up. Start at the bottom and work towards the top. There are a couple of plastic clips along the join and as you work up they will unclip. Once you have done one side you should be able to pull it apart fairly easily.
:) Chris
Jan 15, 2012 | Sony Televison & Video
The drum partician, or the tumbler bars are plastic and one of them broke off. I would like to replace it. Can I lift the top of the dryer off to access the screws on the outside of the drum?
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be replaced. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I replaced it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Sep 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
Gateway M-6750 Motherboard Power Short, Little Clips
Had the same issue. Clip fell off, moved around, hit the motherboard and it fried. I hope there is a class action lawsuit against gateway
Replacement motherboard $400, new Lappy $600.
Jun 09, 2009 | Gateway M-6750 Notebook
Loose screws or other,need to enter dryer drum to remove objects...our model is MD5500...does top come off first or front first???? phone # 303-221-0550 or email jerrydhayes@hotmail.com The NOISE is very...
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Mar 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do i change my brake lights?
pull the little round plastic things out around the brake light , fold the carpet down , pull the white plastic clips holding the wires off the bolts. unscrew the nuts there going to be a ten millameter pull the brake light out from the out side and the lights twist out from the houseing , then pull the light out of the socket and put the new one in
Dec 04, 2008 | 1996 Dodge Avenger
How to remove the front door driver side pannel / molding?
Hi Leon, I have a E34 1995 5 series and had to take door cards off. They're predominantly held on by plastic button clips around the edge/circumference of the door card HOWEVER there is a couple of screws hidden, 1 is behind the chrome door pull/lever a little round plastic cover hides it the other is behind the top of door handle maybe on yours behind door mirror electric adjuster button. one scew is philips the other Torx when pulling the card off the clips try a large flat/wide implement to prise it away as you may breaks some of the clips (£2/3 eBay) One more thing the door handle locates into a grip from behind you'll need a long screwdriver to push the tang up to release it. All the above should be well similar to your model. Oh! nearly forgot remember to unscrew/take off the door pin that goes up and down when locked/unlocked
Paul 'W'
Onyer~EDson(:0)~[><
Dec 04, 2008 | 2001 BMW 5 Series
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Dell Inspiron 1501 Notebook Logo
61 people viewed this question
Alun Cox
