I have a 36in. Toshiba tube tv where all of a sudden I have a thin horizontal line across teh center of the screen. Just cutious if it is a simlpe cheap fix or if it needs to be recycled.
  • 121 Answers
Vertical output circuit problem. transistors electrolytics probley need tech  85.00 to 100.00?.
Posted on Dec 10, 2008
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 28, 2009 | Toshiba 36A50 36" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
