Question about Zanussi ZBQ665 Electric Single Oven
Electric oven and hood not working but grill is?
My oven and cooker hood dont seem to be working but the grill within the oven is working ok.
Any ideas?
  • Zanussi Master
  • 3,463 Answers
Make sure the timer is set to manual and not on auto.
Posted on Dec 10, 2008
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Smeg oven UK80MFX1 troubleshooting
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 30, 2011 | Smeg Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
Belling oven & grill not heating ,element been testing by electrician and seems to be ok, fan and lights working
hi you dont mention the model but all bellings have a thermal cut out (Limpet stat) the formats have one on the right hand side . remove the side panel to get to it . other models may be at the back, Also can be under the hotplates if freestanding cooker. look for a button sized cylinder 15mm dia 10mm deep with 2 wires connected. or follow a common wire back from the elements( one of them will go there).
Nov 20, 2010 | Belling Ovens
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Zanussi ZBQ665 Electric Single Oven Logo
265 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
