Question about American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le
Sewer Gas Smell Coming From Bath Tub
We had the "smoke" test done twice to test where leaks might be in our sewer system. None were found. The subject bathroom had an Americast Tub installed about 4 months ago. We didn't really notice the problem till the gas-forced-air heating system came on. The air intake for the central HVAC system is in the hall right next to the bathroom. Somehow, sewer gas seems to be getting sucked out of the OVERFLOW vent of the tub and is very strong. I removed the cover plate on the overflow and duct taped the hole completely. This seems to resolve the issue of the sewer gas. Any ideas what would produce this very strong odor? Any thoughts are appreciated.
  • drain and sewer cleaning
    A proper water trap full of water should not let this happen as the overflow pipe should also run in to this trap. The only thing I can think of is if the plumber run the overflow pipe to an air vent instead of the trap or maybe split the pipe, run one pipe to trap and other pipe to air vent.It may sound like a good ideal getting the extra air but it's not. It will let gas into the house. If this is the case I would have the pipe going to air vent stubbed off on both ends, and look for a new plumber.
Hello all, I have been renting a house for over two years and all of a sudden this really bad sewer smell and some type of brownish film goes around the drain almost up to the spout the smell or what ever it is even burns my eyes a bit,this has never happened before it is worse over night,, is this bad for our health, I bleach it about 10 times a day, can anybody please tell me what it is?
Worried Mom
Posted on Aug 27, 2010
    This is called rust it is a hard water stain, mineral deposit from the water.you can clean it with something like iron out or other hard water deposit cleaner, then you might have to look in to getting a filter installed
    Scholar:
  • 75 Answers
I've encountered this problem about 4 or 5 times. It has always been when there is more than one bathroom with more than one tub/shower. What has happened is that one tub/shower hasn't been used for a month or two and the water in the P trap evaporates and then the sewer gas or septic bed gas can come up the pipe into the room. If you have a sink, toilet, shower or any fixture that has a trap, make sure that you pour a cup of water down approx. 1 per month if your aren't using the fixture.
Posted on Nov 12, 2009
  • 33 Answers
I can think of two possible solutions to this issue.
  1. The trap is installed incorrectly. The trap is the portion of the drain that is U shaped under the tub. The wastewater must come out of the tub and into the trap. From the trap it goes into the trap arm which must remain horizontal until it reaches the vent. This is very important. The vent must remain vertical until it is at least 6" above the rim of the tub.
  2. The sewer could be plugged. Not the tub but the main sewer line. When this occurs the water has no where to go so it forces the air in the line to take the path of least resistance and that usually menas the tub since the shower has a 2" trap. You may hear a bubbling sound when flushing. The drain may not be completely plugged so it would appear as an intermittent problem.
Hope this helps and please remember to rate this!
Posted on Dec 10, 2008
    Problem Solver:
  • 6 Answers
I am a plumber and I once dealt with a similar problem. As it turned out there was nothing wrong with the plumbing. Whoever installed the tub spout filled it with plumbers putty! The putty had begun to rot from constant moisture (I know it sound strange) and was giving off the most offensive, sewer gas like odor. The customer had had two other plumbers in before me and she said I couldn't leave until I solved her problem. Who would have thought of removing tyhe tub spout. I had to think outside the box - your problem may require out of the box thinking as well.
Posted on Jun 16, 2009
How can we get rid of the occasional sewer smell in our house?
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
Sep 06, 2014 | Plumbing
What does a freon leak in a deep freeze smell like?
Freon is odorless. A sewer odor could be caused by an unused sink, tub, or floor drain trap where the water has evaporated. A gas odor is a very serious issue that should be checked immediately by the gas company or the fire department. Gas can seep in from a leak outside the house or accumulate in a wall if a fitting fails.
Aug 26, 2014 | Kitchen Appliances - Others
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 | Plumbing
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
Now it is summer, and we have a horrible smell coming out of jacuzzi drainage, what should we use to get rit of the smell
hiya:) all tubs,sinks,etc are plumbed w/a P-trap which holds water and prevents sewer gasses from venting into your home. if the unit has not been used in a while the water may have evaporated, allowing the sewer gas to pass freely into your home. this is not only unpleasant it is potentially dangerous and/or unhealthy. IF the unit has not been in use for some time then just run the water for a min and the smell should go away. If this is not the problem just text me back and we'll go from there:)
Jul 27, 2011 | Whirlpool Aquatic Infinity Ii 2 Tub...
When do you need to vent a bathroom sink?
You always need to vent a sink. If you do not vent the sink it will create a vacume and **** water, or air from the nearest fixture.. example, if you connect to the sewer line near a bath tub, when you run the sink water it will **** air from the bath tub drain. If it sucks a lot of air, you will smell the sewer odor since the water is no longer blocking it.
If you cannot run the vent to the roof, there is an in wall vent valve called a studor vent that may work. Get with someone at Lowes or Home depot to show you one.
Feb 09, 2011 | Home
Have a terrible smell coming out of my tub drain
I hope you put trap back on,or you need to fill trap with water--that is the water seal for sewer gas
Jan 31, 2011 | Kohler 1107-R-0 ProFlex Bath Tub with...
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
jajoy,
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
Sewer gas smell from tub.
Something was flushed that should not have been flushed
You will have to have your drain snaked out.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le Logo
4,312 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
Roscoe007
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
