Question about Kirby Ultimate G Bagged Upright Vacuum
G-4 Kirby self propel unit works in reverse but not foward
Good Kirby but it seems like someone hooked up self propel system back wards.goes good in reverse but pushes hard in forward...I have not took it apart yet just wondered if it is an easy fix..jon
  • sprint368 Dec 11, 2008
    say a diffaculty of 5... Great web site...Thx jon smith
  • Anonymous Mar 25, 2014
    Wheels hardly move hard to push
  • 357 Answers
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Posted on Dec 11, 2008
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 self propel problem
There is an adjustment for the transmission and it is wrong. It could also be worn. The Kirby has an amazing warranty. See if you can get it serviced for free.
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I just bought a Hoover Power Drive Concept Two Electronic vacuum from the thrift shop. It only needed two belts and seems powerful. But i don't understand what the small red button on the handle marked...
The U6311-903 is a self propelled vacuum. The the small red button will stop the handle from moving back and forth, which makes the machine go foward and backwards. The red button disengages the self propelled feature.
Feb 06, 2010 | Hoover U6311-930 Power Drive Bagged...
G-5 Kirby self-propel works intermitently. The handle must be jiggled until it engages forward. The same for reverse. Once underway it will continue indefinitely until the need to change direction. Jiggle...
sounds like a loose wire, the wire is connected to the handle, you may be able to fix this yourself but be careful you can void the warranty by doing it your self. (most people make the problem worse) remember your kirby has a lifetime warranty (limited) the first 3 years anything and everything, after that for 175 dollars you can send it in and get it rebuilt to the newest model no matter how old it is as long as the person is still alive that signed the warranty card.
hope that helped.
rob
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Oct 28, 2007 | Hoover Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
609 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
