Question about HP Office Equipment & Supplies
I have alot of printing
I have a lot of printing to do,can i tell the deskjet   HP F4180 to only print in black,to save money on colour cartrtidges
  • 124 Answers
Yes.  Open the Printers and Faxes dialog from Control Panel. Right click your printer and hit Properties. There should be an option (possibly under Advanced) to change to GrayScale or Black and White. Print a doc, then I'd just double check before you print a 2nd doc that it kept the setting. If it did, go ahead and print the rest. If it didn't, try setting it again and recheck.
Posted on Dec 10, 2008
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
My hp deskjet f4180 printeris acting like it is printing, but the pages are coming out blank. The cartriges are new, they worked for the first few pages, then it started printing lighter, and lighter...
Hello. It sounds like the cartridges are running empty, strange that new cartridges would run empty so quickly. Depending on the cartridge number the 21 and 22 are very low capacity. you do have the option of using a 57 colour also which has approx double the capacity, but unfortunately the black is only a 190 page cartridge (according to them, real world testing has shown much less)
If it has been refilled try this link below to get it flowing again. http://www.fixya.com/support/r3986425-unblock_print_heads
If the Cartridges are HP Brand jump on the phone to HP to obtain a replacement cartridge.
F.Y.I Most compatible cartridges (21 and 22) have a capacity of approx 20ml of ink, compared to HP that hold approx 6ml. I would recommended SkyWell Brand of compatibles as they have great colour and a large capactiy.
I hope this helps Regards GM
Apr 26, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
My HP PRINTER,DESKJET F4180 is printing faintly even though there is a lot of ink
I presume that you have tried with different cartridges to rule out the possibility of cartridge fault and you are not printing in draft mode.
Clean the electrical contacts on the cartirdges and carriage.
The steel rod, on which the carriage moves, is set too far away from the paper. Open the printer's top cover and loosen the lock screw of the brackets holding the rod by its ends. Rotate these brackets a few degrees to lower the print carriage towards the paper to obtain desired printing. The screws to tightened.
Feb 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Installing ink cartridges
don't know how to install ink in my f4180 printer. Have new cartridges 21 and 22
May 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
New HP printer Deskjet F4180 will not print
Hey
Try to take the cartridges out and clean the cartridges and cartridge holder with damp clothe
now shake the cartrdges and clean it agaian with damp cloth
put the cartridges back in and see if it works
Sep 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I have a HP Deskjet F4180 AIO. It is printing
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 08, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
My printer is not printing text in neither colour nor grayscale.
Go to Word>>
In new Documents
Type following with Big font size, their respective colour
BLACK
RED
BLUE
YELLOW
Now you will come to know which colour is not printing, in case any problem in nozzel or print head.
Secondly, go to Notepad and try printing somthing from that.
Please try this and provide your experience
Jan 05, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
23 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
